Up to 20% off select tools
Zig-zag Patch
Views: 41K
View statistics:
Past 24 Hours:
16
Past 7 Days:
122
Past 30 Days:
531
All Time:
41,466
Comments: 1
1 comment on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 42
42 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Zig-zag Patch
Introduction
Go to step 1 ↓
You've seen those jeans, the $200 pair that come pre-damaged, covered in contrasting stitches. Don't bother. Instead, follow this guide to not only fix your jeans, but upgrade them in style.
Return to the Patagonia Care & Repair homepage.
    1. Zig-zag Patch, Zig-zag Patch: step 1, image 1 of 3 Zig-zag Patch, Zig-zag Patch: step 1, image 2 of 3 Zig-zag Patch, Zig-zag Patch: step 1, image 3 of 3
      • Examine the damage. Clip any long, loose threads, and remove any debris from the hole.
      • Measure the length and width of the hole.
      • In our case it looks like 2" by 1".
      Ask FixBot
    2. Zig-zag Patch: step 2, image 1 of 3 Zig-zag Patch: step 2, image 2 of 3 Zig-zag Patch: step 2, image 3 of 3
      • Grab a scrap of denim or other heavy-weight fabric and mark your measurements plus one inch in each direction.
      • In our case it will be 3" by 2".
      • Cut the scrap into a rectangle the dimensions of your new measurements.
      Ask FixBot
    3. Zig-zag Patch: step 3, image 1 of 2 Zig-zag Patch: step 3, image 2 of 2
      • Insert the rectangle of fabric into the jean leg and position it under the hole.
      • Be sure that you put the rectangle of fabric in the pant leg and not behind it—you only want to work on one layer of fabric.
      Ask FixBot
    4. Zig-zag Patch: step 4, image 1 of 3 Zig-zag Patch: step 4, image 2 of 3 Zig-zag Patch: step 4, image 3 of 3
      • Thread your sewing machine with your desired thread color.
      • Slide the pant leg onto the arm of the sewing machine.
      • You may need to remove the sewing machine table for the pant leg to fit over the arm.
      • Be sure that the pant leg is around the arm of the sewing machine. If both layers are stacked on one another, you will sew the pant leg shut.
      Ask FixBot
    5. Zig-zag Patch: step 5, image 1 of 3 Zig-zag Patch: step 5, image 2 of 3 Zig-zag Patch: step 5, image 3 of 3
      • Check that the rectangle of fabric is still laying flat, centered beneath the hole.
      • Lower the pressor foot.
      • Sew a straight line over the hole going about five stitches past the damage.
      Ask FixBot
    6. Zig-zag Patch: step 6, image 1 of 3 Zig-zag Patch: step 6, image 2 of 3 Zig-zag Patch: step 6, image 3 of 3
      • Lift the pressor foot.
      • Rotate the jean leg a few degrees toward the center of the hole.
      • Engage the backstitch function on your sewing machine, and sew a straight line back over the hole, going about five stitches beyond the damage.
      Ask FixBot
    7. Zig-zag Patch: step 7, image 1 of 3 Zig-zag Patch: step 7, image 2 of 3 Zig-zag Patch: step 7, image 3 of 3
      • Repeat steps five and six, continuing to rotate and sew lines of stitching back and forth until you cover the entire hole.
      Ask FixBot
    8. Zig-zag Patch: step 8, image 1 of 2 Zig-zag Patch: step 8, image 2 of 2
      • When you are satisfied with your stitching, backstitch two or three stitches.
      • Lift the needle and pressor foot.
      • Slide the jean leg off of the sewing machine.
      Ask FixBot
    9. Zig-zag Patch: step 9, image 1 of 2 Zig-zag Patch: step 9, image 2 of 2
      • Clip any dangling threads and admire your work.
      Ask FixBot
    10. Zig-zag Patch: step 10, image 1 of 3 Zig-zag Patch: step 10, image 2 of 3 Zig-zag Patch: step 10, image 3 of 3
      • Still not satisfied? Alrighty, let's add some decorative stitching the other way.
      • This is completely optional. If you are happy with your work, you can stop here.
      • Slide the pant leg back onto the arm of the sewing machine, making sure that the leg goes around the arm.
      Ask FixBot
    11. Zig-zag Patch: step 11, image 1 of 2 Zig-zag Patch: step 11, image 2 of 2
      • Carefully rotate the jean leg 90 degrees.
      • Be sure that there is only one layer of fabric (plus the rectangle) between the sewing machine and the needle, or else you will sew the pant leg shut.
      Ask FixBot
    12. Zig-zag Patch: step 12, image 1 of 2 Zig-zag Patch: step 12, image 2 of 2
      • Sew a straight line of stitching over the damaged area.
      Ask FixBot
    13. Zig-zag Patch: step 13, image 1 of 3 Zig-zag Patch: step 13, image 2 of 3 Zig-zag Patch: step 13, image 3 of 3
      • Just like before, at the end of each line of stitching, lift the pressor foot, rotate the jeans a few degrees, and sew another line of stitching.
      • When you are happy with the way that the stitching looks, backstitch two or three stitches.
      Ask FixBot
    14. Zig-zag Patch: step 14, image 1 of 2 Zig-zag Patch: step 14, image 2 of 2
      • Lift the pressor foot and needle.
      • Slide the pant leg off the arm of the sewing machine.
      Ask FixBot
    15. Zig-zag Patch: step 15, image 1 of 2 Zig-zag Patch: step 15, image 2 of 2
      • Clip any dangling threads.
      Ask FixBot
Ta-da! Nice work.
8 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 122
Past 30 Days: 531
All Time: 41,466
