Introduction
According to Zhiyun Q3 documentation this battery is a non replaceable part.
After disassembling my Gimbal got the serial number off the existing battery. I easily found a replacement on Aliexpress for $27 CAD.
The battery swap is very simple.
Remove the Phillips screw located inside the 1/4-20 tripod mount hole. Put the screw in a safe place.
Use a Opening Pick to pry the two halves of the grip apart. They are held together with 8 clips.
I found that inserting the Opening Pick near the tripod hole to work the best.
Once the first clip releases the remaining clips should separate easily.
Unplug the old battery. I gave a gentle tug on the wires to separate the plug from the plug socket on the PCB.
The battery is stuck in place with sticky foam. Pull the battery out. the foam can be reused on the new battery.
The first photo shows the old battery removed from the Gimbal.
The second photo shows the sticky foam transferred to the new battery.
Plug in the new battery and position it in place.
Before reassembling the Gimbal turn it on to test the new battery is connected properly.
To reassemble your device, carefully snap the two halves together.
Make sure to route the battery wires above the batter so they don't get squished between the battery and the inside of the grip.
Put the Phillips screw back in and snug it up.
After installing the new battery plug in a charger and fully charge the battery.
My new battery was charged somewhere between the 0-25% range based on the LED's blinking while charging.
