Zerotow V3 Boogie Dual battery Kit Installation
    • Remove the battery from the Boogie
    • Place the Boogie on the trolley. This helps support and protect the motor
    • Inflate the Boogies hull to 1-2psi
    • Fully open the zip
    • This guide was photographed outside of a Boogie hull for better angles and lighting.
    Ask FixBot
    • Remove GPS from back of the control Box.
    • The GPS is held in place with 3M dual lock velcro and can be pulled of without tools
    • Be careful to no tug on the GPS cable as it is fragile
    Ask FixBot
    • Use a #1 Phillips screwdriver to loosen the screws and then lift off the case.
    Ask FixBot
    • Wiggle to top plate from side to side to remove it.
    • The top plate it is not held down with any screws.
    • If the bearings stay on the shafts that is ok, they can be removed later.
    • Do not unplug the top plate.
    • Remove the the extra cable in the slot so you have room to move the top plate to the side.
    Ask FixBot
    • Lift the PCB out of the way to expose the speed controller
    • Do not unplug any cables from the PCB
    Ask FixBot
    • Remove the plugs either side of the antenna using a philips screw driver.
    Ask FixBot
    • Insert the glands on to the cables.
    • Threaded end towards the cable lugs
    Ask FixBot
    • Pass the cable though the holes either side of the antenna.
    • You can bend the lugs and cable slightly by hand first to make it easier to pass though.
    • Pass the cables through the same sides as the existing cables - Orange on the left side of the Boogie, and Black on the right.
    Ask FixBot
Mark Duyvesteyn
633 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 68
