Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓Some of the locking mechanisms on the Boogie battery and charger connectors have broken during use. If this happens, the connector may become loose or disconnect unexpectedly.
We think this is due to very small tolerance error during the manufacture of the connector by a 3rd party.
Fortunately, the repair is relatively simple. By reassembling the locking mechanism and carefully using a soldering iron or lighter and nail to fuse the plastic components together, you can create a stronger bond than the original factory assembly.
Locate the parts - they will inside the Boogie some where.
There are three parts to the mechanisum - the locking tab, a spring and the cover
Re assemble as shown in the photos
Hold the cap in as best you can until the next step
Use either a soldering iron or a nail heated with a lighter or blow torch
Hold the cap in positon and press the heated nail or soldering iron into the plastic to melt the plastic and create a secure bond.
