Zenbre SoundBank Z3 Speaker Replacement
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: step 1, image 1 of 2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: step 1, image 2 of 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
    Ask FixBot
  2. Zenbre SoundBank Z3 Speaker Replacement: step 2, image 1 of 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
    Ask FixBot
  3. Zenbre SoundBank Z3 Speaker Replacement: step 3, image 1 of 2 Zenbre SoundBank Z3 Speaker Replacement: step 3, image 2 of 2
    • Remove the bottom panel speaker using an iFixit opening tool.
    Ask FixBot
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: step 4, image 1 of 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: step 4, image 2 of 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: step 4, image 3 of 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
    Ask FixBot
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: step 5, image 1 of 2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: step 5, image 2 of 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
    Ask FixBot
  6. Zenbre SoundBank Z3 Speaker Replacement: step 6, image 1 of 2 Zenbre SoundBank Z3 Speaker Replacement: step 6, image 2 of 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
    Ask FixBot
  7. Zenbre SoundBank Z3 Speaker Replacement: step 7, image 1 of 2 Zenbre SoundBank Z3 Speaker Replacement: step 7, image 2 of 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
    Ask FixBot
Cherian Thomas
334 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 788
