Zenbre SoundBank Z3 Motherboard Replacement
  1. Zenbre SoundBank Z3 Motherboard Replacement, Bottom Cover: step 1, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement, Bottom Cover: step 1, image 2 of 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
    Ask FixBot
  2. Zenbre SoundBank Z3 Motherboard Replacement: step 2, image 1 of 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
    Ask FixBot
  3. Zenbre SoundBank Z3 Motherboard Replacement: step 3, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement: step 3, image 2 of 2
    • Remove the bottom panel speaker using an iFixit opening tool.
    Ask FixBot
  4. Zenbre SoundBank Z3 Motherboard Replacement, Motherboard Cover: step 4, image 1 of 3 Zenbre SoundBank Z3 Motherboard Replacement, Motherboard Cover: step 4, image 2 of 3 Zenbre SoundBank Z3 Motherboard Replacement, Motherboard Cover: step 4, image 3 of 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
    Ask FixBot
  5. Zenbre SoundBank Z3 Motherboard Replacement, Battery: step 5, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement, Battery: step 5, image 2 of 2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
    Ask FixBot
  6. Zenbre SoundBank Z3 Motherboard Replacement: step 6, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement: step 6, image 2 of 2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
    Ask FixBot
  7. Zenbre SoundBank Z3 Motherboard Replacement: step 7, image 1 of 1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
    Ask FixBot
  8. Zenbre SoundBank Z3 Motherboard Replacement, Speakers: step 8, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement, Speakers: step 8, image 2 of 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
    Ask FixBot
  9. Zenbre SoundBank Z3 Motherboard Replacement: step 9, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement: step 9, image 2 of 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
    Ask FixBot
  10. Zenbre SoundBank Z3 Motherboard Replacement: step 10, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement: step 10, image 2 of 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
    Ask FixBot
  11. Zenbre SoundBank Z3 Motherboard Replacement, Motherboard: step 11, image 1 of 2 Zenbre SoundBank Z3 Motherboard Replacement, Motherboard: step 11, image 2 of 2
    • Remove these two 4.5 mm Philips silver screws holding down the motherboard.
    • The motherboard should be able to be lifted right out of the housing.
    Ask FixBot
  12. Zenbre SoundBank Z3 Motherboard Replacement: step 12, image 1 of 3 Zenbre SoundBank Z3 Motherboard Replacement: step 12, image 2 of 3 Zenbre SoundBank Z3 Motherboard Replacement: step 12, image 3 of 3
    • You will finds a ribbon cable connecting the motherboard to the control interface circuit board.
    • Using a spudger or plastic opening tool, lift flap on the ribbon cable ZIF connector.
    • Using a plastic pry tool or fine tip plastic tool to open the clamp.
    • Using the tool, try lifting the clamp up on either location, noted by the blue arrow.
    • The ribbon should pop out, if not you should be able to slide it out from the clamp.
    Ask FixBot
2 other people completed this guide.
Samuel Knapik
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 683
