Zenbre SoundBank Z3 Battery Replacement
    1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: step 1, image 1 of 2 Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: step 1, image 2 of 2
      • Power off the SoundBank Z3.
      • Turn over the device.
      • Peel the silicone feet up to remove.
      • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
      Ask FixBot
    2. Zenbre SoundBank Z3 Battery Replacement: step 2, image 1 of 1
      • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
      Ask FixBot
    3. Zenbre SoundBank Z3 Battery Replacement: step 3, image 1 of 2 Zenbre SoundBank Z3 Battery Replacement: step 3, image 2 of 2
      • Remove the bottom panel speaker using an iFixit opening tool.
      Ask FixBot
    1. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: step 4, image 1 of 3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: step 4, image 2 of 3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: step 4, image 3 of 3
      • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
      • Remove the plastic panel.
      Ask FixBot
    1. Zenbre SoundBank Z3 Battery Replacement, Battery: step 5, image 1 of 2 Zenbre SoundBank Z3 Battery Replacement, Battery: step 5, image 2 of 2
      • Remove the battery from the holder. It may be difficult the first time.
      • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
      • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
      Ask FixBot
    2. Zenbre SoundBank Z3 Battery Replacement: step 6, image 1 of 2 Zenbre SoundBank Z3 Battery Replacement: step 6, image 2 of 2
      • Remove the pressure-fitted foam from the slot by hand.
      • Unravel and remove foam from the wires.
      • When reassembling, the foam can be re-wrapped if care is taken when handling it.
      Ask FixBot
    3. Zenbre SoundBank Z3 Battery Replacement: step 7, image 1 of 1
      • Using a soldering iron, remove the leads, separating the battery from motherboard.
      • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
      Ask FixBot
3 other people completed this guide.
Cherian Thomas
334 Reputation
5 Guides authored
3 Guide Comments
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - Reply Share
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas - Reply Share
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 25
All Time: 5,068
