Zeki TBQG884B LCD Screen Replacement
    1. Zeki TBQG884B LCD Screen Replacement, Rear Case: step 1, image 1 of 2 Zeki TBQG884B LCD Screen Replacement, Rear Case: step 1, image 2 of 2
      • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
      Ask FixBot
    2. Zeki TBQG884B LCD Screen Replacement: step 2, image 1 of 1
      • Place the tablet down so that the screen is facing away from you.
      • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
      • Gently work your way around the perimeter of the tablet's edge.
      Ask FixBot
    3. Zeki TBQG884B LCD Screen Replacement: step 3, image 1 of 2 Zeki TBQG884B LCD Screen Replacement: step 3, image 2 of 2
      • Remove the back cover
      • Remove any tape on the speaker and detach the speaker from the back plate.
      • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
      Ask FixBot
    1. Zeki TBQG884B LCD Screen Replacement, Motherboard: step 4, image 1 of 1
      • Disconnect the Wi-Fi antenna cable from the motherboard.
      Ask FixBot
    2. Zeki TBQG884B LCD Screen Replacement: step 5, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
      Ask FixBot
    3. Zeki TBQG884B LCD Screen Replacement: step 6, image 1 of 1
      • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
      Ask FixBot
    4. Zeki TBQG884B LCD Screen Replacement: step 7, image 1 of 1
      • Disconnect the other ZIF connector on the opposite side of the motherboard.
      Ask FixBot
    5. Zeki TBQG884B LCD Screen Replacement: step 8, image 1 of 1
      • Remove the motherboard and now reinsert all connectors into a new motherboard.
      • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
      Ask FixBot
    1. Zeki TBQG884B LCD Screen Replacement, LCD Screen: step 9, image 1 of 1
      • Use an opening tool to detach the clip between the front frame, and the metal loader.
      • There are several clips on each side of the frame. Detach ALL of them before you open the loader.
      Ask FixBot
    2. Zeki TBQG884B LCD Screen Replacement: step 10, image 1 of 1
      • Lift the metal loader up and separate it from the LCD screen.
      • Detach each piece slowly to avoid damaging or dropping any fragile parts.
      Ask FixBot
2 other people completed this guide.
David Wyman
346 Reputation
3 Guides authored
IUPUI, Team 1-3, Harley Fall 2015 Member of IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 33
All Time: 1,696
