Zeki TB782B Motherboard Replacement
  1. Zeki TB782B Motherboard Replacement, Motherboard: step 1, image 1 of 2 Zeki TB782B Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • While wearing your antistatic wristband. Using a plastic spudger, remove the back casing of your tablet.
  2. Zeki TB782B Motherboard Replacement: step 2, image 1 of 1
    • Using a #000 1.5 mm Phillips screwdriver, remove the screws along the inside of the device.
  3. Zeki TB782B Motherboard Replacement: step 3, image 1 of 2 Zeki TB782B Motherboard Replacement: step 3, image 2 of 2
    • Carefully disconnect the wires from the motherboard by rocking them back and forth until they come out.
  4. Zeki TB782B Motherboard Replacement: step 4, image 1 of 1
    • At this point, you should be able to remove the motherboard.
Afterwards, you should have a fully functioning device.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 57
All Time: 231
