Up to 20% off select tools
Zeki Droid Tablet Front Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
92
All Time:
848
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the screen on the Zeki Droid TBDC1093B.
Follow these instructions to disassemble the Zeki Droid and gain access to the broken screen. To prevent injury, I recommend following this guide to reinforce the broken glass.
    1. Zeki Droid Tablet Front Screen Replacement, Back Casing: step 1, image 1 of 1
      • Remove the back casing by slowly popping each tab out with a plastic opening tool.
      Ask FixBot
    2. Zeki Droid Tablet Front Screen Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the tapes one by one from the connecting wires with tweezers.
      Ask FixBot
    3. Zeki Droid Tablet Front Screen Replacement: step 3, image 1 of 1
      • Remove the black clips from both sides of the casing with a plastic opening tool.
      • The clips should pop off separate from the speakers.
      Ask FixBot
    4. Zeki Droid Tablet Front Screen Replacement: step 4, image 1 of 1
      • Remove the speakers from the back casing.
      • Do not tug on the speakers because they are connected to fragile wires.
      Ask FixBot
    5. Zeki Droid Tablet Front Screen Replacement: step 5, image 1 of 1
      • Pull the speakers away from the back casing carefullly.
      Ask FixBot
    1. Zeki Droid Tablet Front Screen Replacement, Front Screen: step 6, image 1 of 1
      • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
      Ask FixBot
    2. Zeki Droid Tablet Front Screen Replacement: step 7, image 1 of 1
      Buy
      • Lift the camera and flash components from their fittings using tweezers.
      Ask FixBot
    3. Zeki Droid Tablet Front Screen Replacement: step 8, image 1 of 1
      • Lift the metal framing to reach the components at the front of the device.
      • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
      Ask FixBot
    4. Zeki Droid Tablet Front Screen Replacement: step 9, image 1 of 2 Zeki Droid Tablet Front Screen Replacement: step 9, image 2 of 2
      • Push the screen forward to remove.
      Ask FixBot
Author
with
Kyla
156 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 92
All Time: 848
