Up to 20% off select tools
Zeepad 7DRK Power and Volume Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
83
All Time:
914
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this repair guide, the Zeepad 7DRK will be taken apart to replace the Volume and Power buttons. This task can be accomplished with a simple soft-tipped prying tool in a short amount of time. The tablet will simply be pried apart to access the buttons.
    1. Zeepad 7DRK Power and Volume Button  Replacement, Power and Volume Buttons: step 1, image 1 of 1
      • First find the power and volume buttons so that you are familiar with their location.
      • The smaller button is the power button and the larger button is the volume button.
      Ask FixBot
    2. Zeepad 7DRK Power and Volume Button  Replacement: step 2, image 1 of 2 Zeepad 7DRK Power and Volume Button  Replacement: step 2, image 2 of 2
      • To open the tablet, use one of the soft-tip prying tools.
      • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
      Ask FixBot
    3. Zeepad 7DRK Power and Volume Button  Replacement: step 3, image 1 of 1
      • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
      • This is what the tablet looks like when pried apart.
      Ask FixBot
    4. Zeepad 7DRK Power and Volume Button  Replacement: step 4, image 1 of 2 Zeepad 7DRK Power and Volume Button  Replacement: step 4, image 2 of 2
      • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
      • In the second picture, the volume control button is shown. Again notice the small locator rings.
      Ask FixBot
    5. Zeepad 7DRK Power and Volume Button  Replacement: step 5, image 1 of 2 Zeepad 7DRK Power and Volume Button  Replacement: step 5, image 2 of 2
      • Now remove the old or broken buttons, and replace them.
      Ask FixBot
Author
with
Trevor Taylor
234 Reputation
2 Guides authored
UMass Dartmouth, Team 6-8, Martin Fall 2016 Member of UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 83
All Time: 914
