Up to 20% off select tools
Zeepad 7DRK Battery Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
88
All Time:
1,221
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide is going to explain the process of deconstruction of the Zeepad 7DRK and eventual removal of the device's battery for easy replacement.
    1. Zeepad 7DRK Battery Replacement, Battery: step 1, image 1 of 2 Zeepad 7DRK Battery Replacement, Battery: step 1, image 2 of 2
      • Begin the process by prying off the back of the Zeepad using the opening tool.
      • Start by edging the corner of the opening tool into the edge of the device and work your way from there until the back cover is removed.
      Ask FixBot
    2. Zeepad 7DRK Battery Replacement: step 2, image 1 of 1
      • Once the back casing has been removed, identify the location of the battery inside the device, marked with the red circle.
      Ask FixBot
    3. Zeepad 7DRK Battery Replacement: step 3, image 1 of 3 Zeepad 7DRK Battery Replacement: step 3, image 2 of 3 Zeepad 7DRK Battery Replacement: step 3, image 3 of 3
      • Identify the pieces of tape holding the battery to the back of the screen, and peel them off to remove them.
      Ask FixBot
    4. Zeepad 7DRK Battery Replacement: step 4, image 1 of 3 Zeepad 7DRK Battery Replacement: step 4, image 2 of 3 Zeepad 7DRK Battery Replacement: step 4, image 3 of 3
      • Locate the connection between the battery and motherboard, and disconnect it by pulling the two apart.
      Ask FixBot
    5. Zeepad 7DRK Battery Replacement: step 5, image 1 of 3 Zeepad 7DRK Battery Replacement: step 5, image 2 of 3 Zeepad 7DRK Battery Replacement: step 5, image 3 of 3
      • To finally finish removing the battery, the two wires connecting to it must be separated.
      • Peel back the tape covering the origin of the wires.
      • Finally, remove the two metal connectors attached to the green piece from the battery with a tug.
      • The battery has now been successfully removed.
      Ask FixBot
Author
with
Alexandra Souza
222 Reputation
2 Guides authored
UMass Dartmouth, Team 6-8, Martin Fall 2016 Member of UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 88
All Time: 1,221
