Zebra ZP 505 Peel and Present System Replacement
  1. Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: step 1, image 1 of 2 Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: step 1, image 2 of 2
    • Orient the printer so that the bottom is facing up.
    • Remove the three P1 9mm screws located on the bottom of the printer and remove the lower unit.
    Ask FixBot
  2. Zebra ZP 505 Peel and Present System Replacement: step 2, image 1 of 2 Zebra ZP 505 Peel and Present System Replacement: step 2, image 2 of 2
    • Remove the P0 9mm screw.
    • Proceed to remove the cover.
    Ask FixBot
  3. Zebra ZP 505 Peel and Present System Replacement: step 3, image 1 of 1
    • Disconnect the harness.
    • Thread the harness through the hole on the right hand side.
    Ask FixBot
  4. Zebra ZP 505 Peel and Present System Replacement: step 4, image 1 of 1
    • Remove the peel and present system by utilizing a metal spudger.
    Ask FixBot
  5. Zebra ZP 505 Peel and Present System Replacement: step 5, image 1 of 1
    • Remove the peel and present system.
    Ask FixBot
Brian Jagger
316 Reputation
3 Guides authored
Cal Poly, Team S8-G2, Banghart Fall 2017 Member of Cal Poly, Team S8-G2, Banghart Fall 2017
CPSU-BANGHART-F17S8G2
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,115
