Zebra ZP 450 Motherboard Replacement
    1. Zebra ZP 450 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
      • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
      Ask FixBot
    2. Zebra ZP 450 Motherboard Replacement: step 2, image 1 of 1
      • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
      Ask FixBot
    3. Zebra ZP 450 Motherboard Replacement: step 3, image 1 of 1
      • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
      Ask FixBot
    4. Zebra ZP 450 Motherboard Replacement: step 4, image 1 of 3 Zebra ZP 450 Motherboard Replacement: step 4, image 2 of 3 Zebra ZP 450 Motherboard Replacement: step 4, image 3 of 3
      • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
      • Remove all connections to the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 793
