Zebra GK420t Platten Rollers Replacement
  1. Zebra GK420t Platten Rollers Replacement, Removing The Roller: step 1, image 1 of 2 Zebra GK420t Platten Rollers Replacement, Removing The Roller: step 1, image 2 of 2
    • Power Off the device and open the main cover
    • locate the 2 tabs on either side of the roller and push them outwards to release them
    • Pull up on both tabs to release the roller from the printer
    Ask FixBot
  2. Zebra GK420t Platten Rollers Replacement, Building the New Roller: step 2, image 1 of 3 Zebra GK420t Platten Rollers Replacement, Building the New Roller: step 2, image 2 of 3 Zebra GK420t Platten Rollers Replacement, Building the New Roller: step 2, image 3 of 3
    • The new Roller will be packaged in separate sections in the order that it needs building
    • Starting on the right the shorter side of the roller place 1 tab
    • On the left side of the roller place the other tab and then the cog to secure the tab in place
    Ask FixBot
  3. Zebra GK420t Platten Rollers Replacement, Fitting the Roller: step 3, image 1 of 3 Zebra GK420t Platten Rollers Replacement, Fitting the Roller: step 3, image 2 of 3 Zebra GK420t Platten Rollers Replacement, Fitting the Roller: step 3, image 3 of 3
    • Make sure the printer is clear of debris
    • Insert the roller keeping the tabs up
    • Once inserted push the tabs down to lock in place with the body of the printer
    Ask FixBot
IT Asset Team
147 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 49
All Time: 945
