Zeal Optics iON Viewfinder Assembly Replacement
  1. Zeal Optics iON Viewfinder Assembly Replacement, Lens: step 1, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement, Lens: step 1, image 2 of 2
    • In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
    • Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
    • Pull the rubber housing apart to release the first two clips.
    Ask FixBot
  2. Zeal Optics iON Viewfinder Assembly Replacement: step 2, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 2, image 2 of 2
    • Grab the inside of the plastic nose rest with your thumb and index finger.
    • Rotate the nose rest upwards until you feel that it is free from the lens.
    Ask FixBot
  3. Zeal Optics iON Viewfinder Assembly Replacement: step 3, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 3, image 2 of 2
    • Rotate the device 180 degrees.
    • Grab the top of the goggle frame that holds the camera assembly.
    • Rotate the frame outwards until you feel that the clips inside it are free.
    Ask FixBot
  4. Zeal Optics iON Viewfinder Assembly Replacement: step 4, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 4, image 2 of 2
    • While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
    Ask FixBot
  5. Zeal Optics iON Viewfinder Assembly Replacement: step 5, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 5, image 2 of 2
    • The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips.
    • While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
    Ask FixBot
  6. Zeal Optics iON Viewfinder Assembly Replacement, Camera Assembly: step 6, image 1 of 1
    • Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
    Ask FixBot
  7. Zeal Optics iON Viewfinder Assembly Replacement: step 7, image 1 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 7, image 2 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 7, image 3 of 3
    • Peel back the rubber battery cover from the inner left side of the frame.
    • While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
    Ask FixBot
  8. Zeal Optics iON Viewfinder Assembly Replacement: step 8, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 8, image 2 of 2
    • Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
    Ask FixBot
  9. Zeal Optics iON Viewfinder Assembly Replacement: step 9, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 9, image 2 of 2
    • Pull the battery out of its recess in the frame.
    • The battery is connected to the entire camera assembly and cannot be completely removed by itself.
    Ask FixBot
  10. Zeal Optics iON Viewfinder Assembly Replacement: step 10, image 1 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 10, image 2 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 10, image 3 of 3
    • Peel the rubber keypad cover up from the inner right side of the frame.
    • While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
    Ask FixBot
  11. Zeal Optics iON Viewfinder Assembly Replacement: step 11, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 11, image 2 of 2
    • Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
    Ask FixBot
  12. Zeal Optics iON Viewfinder Assembly Replacement: step 12, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 12, image 2 of 2
    • Hold the strap mount cover away from the frame and remove the keypad.
    Ask FixBot
  13. Zeal Optics iON Viewfinder Assembly Replacement: step 13, image 1 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 13, image 2 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 13, image 3 of 3
    • Grab the viewfinder housing and pull it out of its recess.
    • Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
    Ask FixBot
  14. Zeal Optics iON Viewfinder Assembly Replacement: step 14, image 1 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 14, image 2 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 14, image 3 of 3
    • Place one of your hands near the center of the frame with your thumb next to the camera housing.
    • With your other hand, grab the camera housing and pull it up and out of the frame.
    Ask FixBot
  15. Zeal Optics iON Viewfinder Assembly Replacement: step 15, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 15, image 2 of 2
    • Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
    Ask FixBot
  16. Zeal Optics iON Viewfinder Assembly Replacement: step 16, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 16, image 2 of 2
    • In the same manner described above, remove the battery from the frame.
    Ask FixBot
  17. Zeal Optics iON Viewfinder Assembly Replacement, Motherboard Assembly: step 17, image 1 of 1
    • Remove the following four screws securing the back cover of the camera housing:
    • two silver 8.5 mm screws,
    • two black 8.8 mm screws.
    Ask FixBot
  18. Zeal Optics iON Viewfinder Assembly Replacement: step 18, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 18, image 2 of 2
    • Peel the white sticker off the bottom of the camera housing.
    Ask FixBot
  19. Zeal Optics iON Viewfinder Assembly Replacement: step 19, image 1 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 19, image 2 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 19, image 3 of 3
    • Lift the back cover off the camera housing and remove it.
    Ask FixBot
  20. Zeal Optics iON Viewfinder Assembly Replacement: step 20, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 20, image 2 of 2
    • Use the tip of a spudger to pry up the retaining flap of the camera sensor cable ZIF connector on the motherboard.
    • Be sure that you are prying up on the hinged flap, not the connector itself.
    Ask FixBot
  21. Zeal Optics iON Viewfinder Assembly Replacement: step 21, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 21, image 2 of 2
    • Pull the camera sensor ribbon cable straight out of its connector on the motherboard.
    Ask FixBot
  22. Zeal Optics iON Viewfinder Assembly Replacement: step 22, image 1 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 22, image 2 of 3 Zeal Optics iON Viewfinder Assembly Replacement: step 22, image 3 of 3
    • Grab the edge of the motherboard and gently slide it out of the camera housing.
    • There may be some resistance due to the foam pad along the bottom of the camera housing.
    Ask FixBot
  23. Zeal Optics iON Viewfinder Assembly Replacement, Viewfinder Assembly: step 23, image 1 of 3 Zeal Optics iON Viewfinder Assembly Replacement, Viewfinder Assembly: step 23, image 2 of 3 Zeal Optics iON Viewfinder Assembly Replacement, Viewfinder Assembly: step 23, image 3 of 3
    • Peel back the Kapton tape covering the viewfinder assembly ribbon cable connector on the motherboard.
    • Use the tip of a spudger to flip up the retaining flap on the viewfinder assembly ribbon cable ZIF connector.
    • Be sure you are prying up on the hinged flap, not the connector itself.
    Ask FixBot
  24. Zeal Optics iON Viewfinder Assembly Replacement: step 24, image 1 of 2 Zeal Optics iON Viewfinder Assembly Replacement: step 24, image 2 of 2
    • Pull the viewfinder assembly ribbon cable straight out of its socket on the motherboard.
    Ask FixBot
David Hodson
156,449 Reputation
127 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 1,398
