Zeal Optics iON LCD Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
88
All Time:
1,806
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Rather than look out through the large lens while skiing down a mountain, you'd rather watch the world unfold through the LCD viewfinder. Not only is this extremely unsafe, it's impossible if your LCD is broken. Replace your broken LCD and get back to living vicariously through your ski goggles.
Tools
    1. Zeal Optics iON LCD Replacement, Lens: step 1, image 1 of 2 Zeal Optics iON LCD Replacement, Lens: step 1, image 2 of 2
      • In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
      • Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
      • Pull the rubber housing apart to release the first two clips.
      Ask FixBot
    2. Zeal Optics iON LCD Replacement: step 2, image 1 of 2 Zeal Optics iON LCD Replacement: step 2, image 2 of 2
      • Grab the inside of the plastic nose rest with your thumb and index finger.
      • Rotate the nose rest upwards until you feel that it is free from the lens.
      Ask FixBot
    3. Zeal Optics iON LCD Replacement: step 3, image 1 of 2 Zeal Optics iON LCD Replacement: step 3, image 2 of 2
      • Rotate the device 180 degrees.
      • Grab the top of the goggle frame that holds the camera assembly.
      • Rotate the frame outwards until you feel that the clips inside it are free.
      Ask FixBot
    4. Zeal Optics iON LCD Replacement: step 4, image 1 of 2 Zeal Optics iON LCD Replacement: step 4, image 2 of 2
      • While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
      Ask FixBot
    5. Zeal Optics iON LCD Replacement: step 5, image 1 of 2 Zeal Optics iON LCD Replacement: step 5, image 2 of 2
      • The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips.
      • While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
      Ask FixBot
    1. Zeal Optics iON LCD Replacement, Camera Assembly: step 6, image 1 of 1
      • Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
      Ask FixBot
    2. Zeal Optics iON LCD Replacement: step 7, image 1 of 3 Zeal Optics iON LCD Replacement: step 7, image 2 of 3 Zeal Optics iON LCD Replacement: step 7, image 3 of 3
      • Peel back the rubber battery cover from the inner left side of the frame.
      • While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
      Ask FixBot
    3. Zeal Optics iON LCD Replacement: step 8, image 1 of 2 Zeal Optics iON LCD Replacement: step 8, image 2 of 2
      • Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
      Ask FixBot
    4. Zeal Optics iON LCD Replacement: step 9, image 1 of 2 Zeal Optics iON LCD Replacement: step 9, image 2 of 2
      • Pull the battery out of its recess in the frame.
      • The battery is connected to the entire camera assembly and cannot be completely removed by itself.
      Ask FixBot
    5. Zeal Optics iON LCD Replacement: step 10, image 1 of 3 Zeal Optics iON LCD Replacement: step 10, image 2 of 3 Zeal Optics iON LCD Replacement: step 10, image 3 of 3
      • Peel the rubber keypad cover up from the inner right side of the frame.
      • While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
      Ask FixBot
    6. Zeal Optics iON LCD Replacement: step 11, image 1 of 2 Zeal Optics iON LCD Replacement: step 11, image 2 of 2
      • Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
      Ask FixBot
    7. Zeal Optics iON LCD Replacement: step 12, image 1 of 2 Zeal Optics iON LCD Replacement: step 12, image 2 of 2
      • Hold the strap mount cover away from the frame and remove the keypad.
      Ask FixBot
    8. Zeal Optics iON LCD Replacement: step 13, image 1 of 3 Zeal Optics iON LCD Replacement: step 13, image 2 of 3 Zeal Optics iON LCD Replacement: step 13, image 3 of 3
      • Grab the viewfinder housing and pull it out of its recess.
      • Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
      Ask FixBot
    9. Zeal Optics iON LCD Replacement: step 14, image 1 of 3 Zeal Optics iON LCD Replacement: step 14, image 2 of 3 Zeal Optics iON LCD Replacement: step 14, image 3 of 3
      • Place one of your hands near the center of the frame with your thumb next to the camera housing.
      • With your other hand, grab the camera housing and pull it up and out of the frame.
      Ask FixBot
    10. Zeal Optics iON LCD Replacement: step 15, image 1 of 2 Zeal Optics iON LCD Replacement: step 15, image 2 of 2
      • Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
      Ask FixBot
    11. Zeal Optics iON LCD Replacement: step 16, image 1 of 2 Zeal Optics iON LCD Replacement: step 16, image 2 of 2
      • In the same manner described above, remove the battery from the frame.
      Ask FixBot
    1. Zeal Optics iON LCD Replacement, Viewfinder Lens Assembly: step 17, image 1 of 2 Zeal Optics iON LCD Replacement, Viewfinder Lens Assembly: step 17, image 2 of 2
      • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
      • Flip the viewfinder housing over 180 degrees.
      • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
      Ask FixBot
    2. Zeal Optics iON LCD Replacement: step 18, image 1 of 2 Zeal Optics iON LCD Replacement: step 18, image 2 of 2
      • Pull the two halves of the viewfinder housing apart.
      Ask FixBot
    3. Zeal Optics iON LCD Replacement: step 19, image 1 of 2 Zeal Optics iON LCD Replacement: step 19, image 2 of 2
      • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
      • Be sure to pry up on the hinged flap, not the connector itself.
      Ask FixBot
    4. Zeal Optics iON LCD Replacement: step 20, image 1 of 2 Zeal Optics iON LCD Replacement: step 20, image 2 of 2
      • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
      Ask FixBot
    5. Zeal Optics iON LCD Replacement: step 21, image 1 of 2 Zeal Optics iON LCD Replacement: step 21, image 2 of 2
      Tool used on this step:
      Buy
      • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
      Ask FixBot
    6. Zeal Optics iON LCD Replacement: step 22, image 1 of 2 Zeal Optics iON LCD Replacement: step 22, image 2 of 2
      • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
      Ask FixBot
    7. Zeal Optics iON LCD Replacement: step 23, image 1 of 2 Zeal Optics iON LCD Replacement: step 23, image 2 of 2
      • Remove the viewfinder lens assembly from the viewfinder housing.
      Ask FixBot
    1. Zeal Optics iON LCD Replacement, LCD Assembly: step 24, image 1 of 2 Zeal Optics iON LCD Replacement, LCD Assembly: step 24, image 2 of 2
      • Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly.
      • Pull the viewfinder lens off of the viewfinder LCD.
      Ask FixBot
    1. Zeal Optics iON LCD Replacement, LCD: step 25, image 1 of 3 Zeal Optics iON LCD Replacement, LCD: step 25, image 2 of 3 Zeal Optics iON LCD Replacement, LCD: step 25, image 3 of 3
      • Use your thumb to push the LCD bracket tab away from the LCD.
      • Remove the LCD bracket from the LCD and backlight.
      Ask FixBot
    2. Zeal Optics iON LCD Replacement: step 26, image 1 of 2 Zeal Optics iON LCD Replacement: step 26, image 2 of 2
      • Using your thumbs, pull the four white tabs on the backlight away from the LCD panel.
      • Remove the LCD from the backlight.
      Ask FixBot
Eric Flores
128 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 88
All Time: 1,806
