Up to 20% off select tools
Zanussi Washing Machine Fault Code Reset
Views: 233K
View statistics:
Past 24 Hours:
26
Past 7 Days:
131
Past 30 Days:
426
All Time:
233,251
Comments: 78
20 comments on steps, 58 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
My Zanussi Washing Machine hasn’t been working properly for a while. then it stopped spinning and emptying, then wouldn’t go through the programmes at all.
I cleaned all the pipes, checked motor brushes, oiled and checked motors, no benefit.
I found this worked though, and left it working perfect -
Next time it goes wonky give it a try first!
Seán
    1. Zanussi Washing Machine Fault Code Reset, Zanussi Washing Machine Fault Code Reset: step 1, image 1 of 1
      • Turn the dial to off.
      • Press and hold together the start button (the one with the green arrow) and the button to the left of it.
      • While holding, turn the Programme Dial 1 ‘click’ clockwise(to 90 degrees temp).
      • The lights ( or digital screen ) will flash - release the buttons (the lights should scroll).
      • Now turn the dial a further 9 clicks clockwise.
      • Note the error code displayed.
      • Continue turning the dial clockwise till you get to off, then turn to any program and back to off.
      Ask FixBot
      • All washing machines will eventually stop working. First try the brushes on the main motor. They wear down, the more work the quicker it will happen. They are usually contained in an external plastic housing, one each at the rear end of the motor and easy to replace.
      Ask FixBot
26 other people completed this guide.
Author
with
keelsean
448 Reputation
1 Guide authored
58 Guide Comments
Fantastic. I had spent a very frustrating hour trying to sort the problem with my machine. Last resort before buying a new one was to trawl the internet. Came across this solution and, bingo, it worked. So pleased and grateful for the info, saved me a bundle!!
suegoldsmith - Reply Share
It shows me E72,what i have to do?
Totorean Marcel - Reply Share
I tried this although in my machine the 'extra rinse' button is not there but a half load button instead. I never the less used this button & what happened is as described. I only needed to turn the dial 8 turns, 40 degrees light wash & the unit made a few cycles then spun at top speed. So far ok. Unfortunately this seems to have upset the programmer which does not follow it's normal pattern of events.
Don't know what to do now except, maybe experiment to get a full wash the go through the procedure again to spin.
Any further help would be appreciated,
Vic Funnell
funvic - Reply Share
Regarding your programmer not displaying the normal wash cycles did you manage to resolve this.
Jackie Murray Bernardo - Reply Share
This has just worked for me. Thanku very much
Julie Acaster - Reply Share
Past 24 Hours: 26
Past 7 Days: 131
Past 30 Days: 426
All Time: 233,251
