Up to 20% off select tools
ZTE ZMax Pro Power Button Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
83
All Time:
3,688
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 6 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the power button on your device. You will need a plastic opening tool, tweezers, and a Phillips #00 screwdriver.
    1. ZTE ZMax Pro Power Button Replacement, Back Panel Assembly: step 1, image 1 of 1
      • Flip the phone over so that the back panel of the phone is facing up.
      • Wedge the plastic opening tool between the black outer panel and the silver side panel.
      • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
      • Continue to do this around all sides of the phone until the back panel has popped all the way off.
      • Removing the back panel may make loud popping noises which is normal.
      Ask FixBot
    2. ZTE ZMax Pro Power Button Replacement: step 2, image 1 of 1
      • Using your fingers, slide the SIM card all the way out of the phone.
      Ask FixBot
    3. ZTE ZMax Pro Power Button Replacement: step 3, image 1 of 2 ZTE ZMax Pro Power Button Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
      Ask FixBot
    4. ZTE ZMax Pro Power Button Replacement: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
      Ask FixBot
    5. ZTE ZMax Pro Power Button Replacement: step 5, image 1 of 1
      • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
      Ask FixBot
    6. ZTE ZMax Pro Power Button Replacement: step 6, image 1 of 2 ZTE ZMax Pro Power Button Replacement: step 6, image 2 of 2
      • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
      Ask FixBot
    7. ZTE ZMax Pro Power Button Replacement: step 7, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
      Ask FixBot
    8. ZTE ZMax Pro Power Button Replacement: step 8, image 1 of 1
      • Flip the phone over so that the screen is facing up.
      • Wedge the plastic opening tool between the screen and the rear panel.
      • Push up on the opening tool to separate the panel from the phone.
      • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
      • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
      Ask FixBot
    1. ZTE ZMax Pro Power Button Replacement, Power Button: step 9, image 1 of 1
      • Use the plastic opening tool to remove the lower left connector on the motherboard.
      Ask FixBot
    2. ZTE ZMax Pro Power Button Replacement: step 10, image 1 of 1
      Buy
      • Use tweezers to pull back on the power button.
      Ask FixBot
    3. ZTE ZMax Pro Power Button Replacement: step 11, image 1 of 1
      • Use the tweezers to pull back on the volume buttons.
      Ask FixBot
    4. ZTE ZMax Pro Power Button Replacement: step 12, image 1 of 1
      • Use the tweezers to pull back on the cable connecting the power and volume button until it is removed.
      Ask FixBot
6 other people completed this guide.
Author
with
Nicholas Leacox
1,739 Reputation
7 Guides authored
Cal Poly, Team S17-G3, Livingston Spring 2018 Member of Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Members
96 Guides authored
1 Guide Comment
Hpw much to repair ()
Manny Carreon - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 83
All Time: 3,688
