ZTE ZMAX Z970 Volume Button Replacement
    1. ZTE ZMAX Z970 Volume Button Replacement, Battery: step 1, image 1 of 2 ZTE ZMAX Z970 Volume Button Replacement, Battery: step 1, image 2 of 2
      • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
      • Pull out the trays.
      Ask FixBot
    2. ZTE ZMAX Z970 Volume Button Replacement: step 2, image 1 of 2 ZTE ZMAX Z970 Volume Button Replacement: step 2, image 2 of 2
      • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
      • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
      Ask FixBot
    3. ZTE ZMAX Z970 Volume Button Replacement: step 3, image 1 of 3 ZTE ZMAX Z970 Volume Button Replacement: step 3, image 2 of 3 ZTE ZMAX Z970 Volume Button Replacement: step 3, image 3 of 3
      • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
      Ask FixBot
    4. ZTE ZMAX Z970 Volume Button Replacement: step 4, image 1 of 2 ZTE ZMAX Z970 Volume Button Replacement: step 4, image 2 of 2
      • Remove the mid frame with the plastic opening tool.
      Ask FixBot
    5. ZTE ZMAX Z970 Volume Button Replacement: step 5, image 1 of 2 ZTE ZMAX Z970 Volume Button Replacement: step 5, image 2 of 2
      • Disconnect the battery from the motherboard.
      Ask FixBot
    6. ZTE ZMAX Z970 Volume Button Replacement: step 6, image 1 of 2 ZTE ZMAX Z970 Volume Button Replacement: step 6, image 2 of 2
      • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
      • Once free from the glue, remove from device.
      • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
      Ask FixBot
    1. ZTE ZMAX Z970 Volume Button Replacement, Volume Button: step 7, image 1 of 2 ZTE ZMAX Z970 Volume Button Replacement, Volume Button: step 7, image 2 of 2
      • Peel off circuit board carefully.
      • The new part will need to be soldered onto the motherboard.
      Ask FixBot
Burak Cengiz
480 Reputation
4 Guides authored
USF Tampa, Team S17-G3, Boczar Spring 2018 Member of USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 43
All Time: 692
