ZTE ZMAX Z970 Screen Replacement
    1. ZTE ZMAX Z970 Screen Replacement, Battery: step 1, image 1 of 2 ZTE ZMAX Z970 Screen Replacement, Battery: step 1, image 2 of 2
      • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
      • Pull out the trays.
      Ask FixBot
    2. ZTE ZMAX Z970 Screen Replacement: step 2, image 1 of 2 ZTE ZMAX Z970 Screen Replacement: step 2, image 2 of 2
      • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
      • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
      Ask FixBot
    3. ZTE ZMAX Z970 Screen Replacement: step 3, image 1 of 3 ZTE ZMAX Z970 Screen Replacement: step 3, image 2 of 3 ZTE ZMAX Z970 Screen Replacement: step 3, image 3 of 3
      • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
      Ask FixBot
    4. ZTE ZMAX Z970 Screen Replacement: step 4, image 1 of 2 ZTE ZMAX Z970 Screen Replacement: step 4, image 2 of 2
      • Remove the mid frame with the plastic opening tool.
      Ask FixBot
    5. ZTE ZMAX Z970 Screen Replacement: step 5, image 1 of 2 ZTE ZMAX Z970 Screen Replacement: step 5, image 2 of 2
      • Disconnect the battery from the motherboard.
      Ask FixBot
    6. ZTE ZMAX Z970 Screen Replacement: step 6, image 1 of 2 ZTE ZMAX Z970 Screen Replacement: step 6, image 2 of 2
      • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
      • Once free from the glue, remove from device.
      • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
      Ask FixBot
    1. ZTE ZMAX Z970 Screen Replacement, Screen: step 7, image 1 of 1
      • Heat up the iOpener for 30 seconds and place on top of the phone for 2 minutes.
      Ask FixBot
    2. ZTE ZMAX Z970 Screen Replacement: step 8, image 1 of 1
      • Wedge the opening picks into all the corners of the phone and lift until the screen comes off.
      Ask FixBot
Ismail Jhaveri
159 Reputation
1 Guide authored
USF Tampa, Team S17-G3, Boczar Spring 2018 Member of USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 59
All Time: 1,659
