ZTE ZFive G LTE Front-Facing Camera Replacement
    1. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: step 1, image 1 of 3 ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: step 1, image 2 of 3 ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: step 1, image 3 of 3
      • Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
      Ask FixBot
    2. ZTE ZFive G LTE Front-Facing Camera  Replacement: step 2, image 1 of 3 ZTE ZFive G LTE Front-Facing Camera  Replacement: step 2, image 2 of 3 ZTE ZFive G LTE Front-Facing Camera  Replacement: step 2, image 3 of 3
      • Remove the battery with an opening tool or fingernail.
      Ask FixBot
    3. ZTE ZFive G LTE Front-Facing Camera  Replacement: step 3, image 1 of 1
      • Unscrew all 16 screws from the mid-frame J000 screwdriver.
      • Set the screws aside.
      Ask FixBot
    4. ZTE ZFive G LTE Front-Facing Camera  Replacement: step 4, image 1 of 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: step 4, image 2 of 2
      • Gently pull up the device body from the inside.
      • Make sure to pull on all four sides as shown here.
      Ask FixBot
    5. ZTE ZFive G LTE Front-Facing Camera  Replacement: step 5, image 1 of 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: step 5, image 2 of 2
      • Once the body is removed, you will see the front facing camera at the top right corner of the device.
      • Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
      Ask FixBot
    6. ZTE ZFive G LTE Front-Facing Camera  Replacement: step 6, image 1 of 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: step 6, image 2 of 2
      Tool used on this step:
      $3.99
      Buy
      • Using angled tweezers, gently pull the ribbon wire up from the body.
      • With the ribbon wire out, you should be able to remove the camera.
      • If there is adhesive on the camera backing, it may require more force to pull the camera out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 61
All Time: 788
