ZTE ZFive G LTE Back Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
76
All Time:
673
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the camera seems cracked and/or not functioning, this is a quick guide on how to remove the existing camera.
Tools
    1. ZTE ZFive G LTE Back Camera Replacement, Back Camera: step 1, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement, Back Camera: step 1, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement, Back Camera: step 1, image 3 of 3
      • Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail.
      Ask FixBot
    2. ZTE ZFive G LTE Back Camera Replacement: step 2, image 1 of 2 ZTE ZFive G LTE Back Camera Replacement: step 2, image 2 of 2
      • Remove all 16 screws with a J000 screwdriver.
      Ask FixBot
    3. ZTE ZFive G LTE Back Camera Replacement: step 3, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 3, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 3, image 3 of 3
      • Remove the battery with an opening tool or fingernail.
      Ask FixBot
    4. ZTE ZFive G LTE Back Camera Replacement: step 4, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 4, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 4, image 3 of 3
      • Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device.
      Ask FixBot
    5. ZTE ZFive G LTE Back Camera Replacement: step 5, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 5, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 5, image 3 of 3
      • Once body is removed, back-facing camera is placed at the top left corner of device.
      • Using an opening tool, pull up the tab of the camera wire ribbon.
      Ask FixBot
    6. ZTE ZFive G LTE Back Camera Replacement: step 6, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 6, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 76
All Time: 673
