ZTE Whirl 2 Screen Replacement
    1. ZTE Whirl 2 Screen Replacement, Battery: step 1, image 1 of 3 ZTE Whirl 2 Screen Replacement, Battery: step 1, image 2 of 3 ZTE Whirl 2 Screen Replacement, Battery: step 1, image 3 of 3
      • Power off your phone before removing the battery.
      • Pry the cover off the back of the phone using your fingers.
      Ask FixBot
    2. ZTE Whirl 2 Screen Replacement: step 2, image 1 of 3 ZTE Whirl 2 Screen Replacement: step 2, image 2 of 3 ZTE Whirl 2 Screen Replacement: step 2, image 3 of 3
      • Pry the battery from the phone using your fingers.
      Ask FixBot
    1. ZTE Whirl 2 Screen Replacement, Back Panel: step 3, image 1 of 3 ZTE Whirl 2 Screen Replacement, Back Panel: step 3, image 2 of 3 ZTE Whirl 2 Screen Replacement, Back Panel: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove four 4 mm screws using a Phillips #00 screwdriver.
      • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
      Ask FixBot
    2. ZTE Whirl 2 Screen Replacement: step 4, image 1 of 3 ZTE Whirl 2 Screen Replacement: step 4, image 2 of 3 ZTE Whirl 2 Screen Replacement: step 4, image 3 of 3
      • Insert an opening pick between the midframe and the digitizer.
      • Move the pick around the midframe to detach the midframe from the digitizer.
      • The lock button and volume buttons may fall out during this process.
      Ask FixBot
    3. ZTE Whirl 2 Screen Replacement: step 5, image 1 of 1
      • Remove the midframe from the digitizer.
      Ask FixBot
    1. ZTE Whirl 2 Screen Replacement, Screen: step 6, image 1 of 2 ZTE Whirl 2 Screen Replacement, Screen: step 6, image 2 of 2
      Buy
      • Use tweezers to pull the lock button and volume stickers out from the side panels.
      • Use the iFixit Opening Tool to unlock the ribbon connector above the camera. Pull the ribbon from the connector.
      Ask FixBot
    2. ZTE Whirl 2 Screen Replacement: step 7, image 1 of 1
      • Use a spudger tool to unlock the screen ribbon cable.
      • Pull the ribbon cable from the connecter with a pair of tweezers.
      Ask FixBot
    3. ZTE Whirl 2 Screen Replacement: step 8, image 1 of 3 ZTE Whirl 2 Screen Replacement: step 8, image 2 of 3 ZTE Whirl 2 Screen Replacement: step 8, image 3 of 3
      • Remove the motherboard to access the screen. Lift the screen away from the front cover and replace.
      Ask FixBot
Molli Reeder
97 Reputation
1 Guide authored
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 Member of UW Stout, Team S1-G1, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 66
All Time: 437
