ZTE Whirl 2 Camera Replacement
    1. ZTE Whirl 2 Camera Replacement, Battery: step 1, image 1 of 3 ZTE Whirl 2 Camera Replacement, Battery: step 1, image 2 of 3 ZTE Whirl 2 Camera Replacement, Battery: step 1, image 3 of 3
      • Power off your phone before removing the battery.
      • Pry the cover off the back of the phone using your fingers.
      Ask FixBot
    2. ZTE Whirl 2 Camera Replacement: step 2, image 1 of 3 ZTE Whirl 2 Camera Replacement: step 2, image 2 of 3 ZTE Whirl 2 Camera Replacement: step 2, image 3 of 3
      • Pry the battery from the phone using your fingers.
      Ask FixBot
    1. ZTE Whirl 2 Camera Replacement, Back Panel: step 3, image 1 of 3 ZTE Whirl 2 Camera Replacement, Back Panel: step 3, image 2 of 3 ZTE Whirl 2 Camera Replacement, Back Panel: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove four 4 mm screws using a Phillips #00 screwdriver.
      • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
      Ask FixBot
    2. ZTE Whirl 2 Camera Replacement: step 4, image 1 of 3 ZTE Whirl 2 Camera Replacement: step 4, image 2 of 3 ZTE Whirl 2 Camera Replacement: step 4, image 3 of 3
      • Insert an opening pick between the midframe and the digitizer.
      • Move the pick around the midframe to detach the midframe from the digitizer.
      • The lock button and volume buttons may fall out during this process.
      Ask FixBot
    3. ZTE Whirl 2 Camera Replacement: step 5, image 1 of 1
      • Remove the midframe from the digitizer.
      Ask FixBot
    1. ZTE Whirl 2 Camera Replacement, Camera: step 6, image 1 of 3 ZTE Whirl 2 Camera Replacement, Camera: step 6, image 2 of 3 ZTE Whirl 2 Camera Replacement, Camera: step 6, image 3 of 3
      • Use the iFixit Opening Tool to disconnect the camera connector by prying up the press fit connector from the motherboard.
      • Remove the camera from the device.
      Ask FixBot
Alana
461 Reputation
4 Guides authored
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 Member of UW Stout, Team S1-G1, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 52
All Time: 434
