ZTE Tempo Rear Camera Replacement
    1. ZTE Tempo Rear Camera Replacement, Rear Camera: step 1, image 1 of 2 ZTE Tempo Rear Camera Replacement, Rear Camera: step 1, image 2 of 2
      • Pry open the back case to get to the back cover.
      • Remove eight 5mm screws with a PH0 screw.
      • Pry open the back cover with a plastic opening tool.
      • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
      • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
      Ask FixBot
    2. ZTE Tempo Rear Camera Replacement: step 2, image 1 of 2 ZTE Tempo Rear Camera Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
      Ask FixBot
    3. ZTE Tempo Rear Camera Replacement: step 3, image 1 of 2 ZTE Tempo Rear Camera Replacement: step 3, image 2 of 2
      • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
      • Lift the rear camera out of the phone.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 58
All Time: 489
