ZTE Tempo Front Screen Assembly Replacement
    1. ZTE Tempo Front Screen Assembly Replacement, Battery: step 1, image 1 of 2 ZTE Tempo Front Screen Assembly Replacement, Battery: step 1, image 2 of 2
      • Use a plastic opening tool to pry open the back case.
      • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
      • Use a plastic opening tool to remove the midframe.
      Ask FixBot
    2. ZTE Tempo Front Screen Assembly Replacement: step 2, image 1 of 3 ZTE Tempo Front Screen Assembly Replacement: step 2, image 2 of 3 ZTE Tempo Front Screen Assembly Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
      • Lift the battery up and remove it from the phone.
      Ask FixBot
    1. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: step 3, image 1 of 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: step 3, image 2 of 3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: step 3, image 3 of 3
      • Use the plastic opening tool to unplug the three connectors.
      Ask FixBot
    2. ZTE Tempo Front Screen Assembly Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to push up on the wire to remove it completely.
      Ask FixBot
    3. ZTE Tempo Front Screen Assembly Replacement: step 5, image 1 of 2 ZTE Tempo Front Screen Assembly Replacement: step 5, image 2 of 2
      • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
      Ask FixBot
    4. ZTE Tempo Front Screen Assembly Replacement: step 6, image 1 of 3 ZTE Tempo Front Screen Assembly Replacement: step 6, image 2 of 3 ZTE Tempo Front Screen Assembly Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use the metal spudger to push up to remove the volume control.
      • Use the tweezers to remove the front speaker and bottom controller.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 62
All Time: 689
