ZTE Telstra T95 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
91
All Time:
908
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Replace the battery on your ZTE Telstra T95 in three easy steps. No background information necessary.
Tools
    1. ZTE Telstra T95 Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
      • You may also use your finger nail if you do not have a plastic opening tool at hand.
      Ask FixBot
    2. ZTE Telstra T95 Battery Replacement: step 2, image 1 of 1
      • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
      • The battery snaps out of place and you can remove it using your fingers.
      • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
      Ask FixBot
Jeesenia Rios
300 Reputation
2 Guides authored
Gateway, Team 1-1, Johnson Fall 2014 Member of Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 91
All Time: 908
