ZTE Quest n817 Camera Replacement
    1. ZTE Quest n817 Camera Replacement, Battery: step 1, image 1 of 3 ZTE Quest n817 Camera Replacement, Battery: step 1, image 2 of 3 ZTE Quest n817 Camera Replacement, Battery: step 1, image 3 of 3
      • Ensure that the phone is turned off before starting.
      • Orient the device so that the inset on the right side of the device is facing you.
      • Insert the spudger into the inset and carefully remove the back panel.
      Ask FixBot
    2. ZTE Quest n817 Camera Replacement: step 2, image 1 of 2 ZTE Quest n817 Camera Replacement: step 2, image 2 of 2
      • Use the ribbon to remove the exposed battery.
      Ask FixBot
    1. ZTE Quest n817 Camera Replacement, Motherboard: step 3, image 1 of 1
      • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
      Ask FixBot
    2. ZTE Quest n817 Camera Replacement: step 4, image 1 of 1
      • Carefully pry open the back panel with the plastic opening tool.
      Ask FixBot
    3. ZTE Quest n817 Camera Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
      Ask FixBot
    4. ZTE Quest n817 Camera Replacement: step 6, image 1 of 1
      • Pull back the tape encasing the brown ribbon cable connector.
      • Remove the ribbon cable from its socket.
      Ask FixBot
    5. ZTE Quest n817 Camera Replacement: step 7, image 1 of 1
      • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
      Ask FixBot
    6. ZTE Quest n817 Camera Replacement: step 8, image 1 of 2 ZTE Quest n817 Camera Replacement: step 8, image 2 of 2
      • Disconnect the coaxial connector in the bottom right corner of the motherboard.
      Ask FixBot
    1. ZTE Quest n817 Camera Replacement, Camera: step 9, image 1 of 1
      Buy
      • Flip the motherboard over and find the camera’s flat-top connector.
      • Gently pry up each side of the connector with a pair of tweezers before fully removing it.
      Ask FixBot
Eric Loureiro
606 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 34
All Time: 646
