Up to 20% off select tools
ZTE Max XL Display Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
73
All Time:
654
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 50 minutes - 1 hour
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide has step by step instructions on how to replace your ZTE Max XL Screen Display.
    1. ZTE Max XL Display Replacement, Display: step 1, image 1 of 2 ZTE Max XL Display Replacement, Display: step 1, image 2 of 2
      • Before disassembly, assure the phone is powered off.
      • Use the SIM Card remover key, remove the SIM Card tray. To do this insert the key into the hole on the side of the phone near the SIM Card tray.
      Ask FixBot
    2. ZTE Max XL Display Replacement: step 2, image 1 of 1
      • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide
      • On our phone there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
      • Do not heat the phone too much in one area - it may warp the plastic backing.
      Ask FixBot
    3. ZTE Max XL Display Replacement: step 3, image 1 of 3 ZTE Max XL Display Replacement: step 3, image 2 of 3 ZTE Max XL Display Replacement: step 3, image 3 of 3
      • Starting at one corner, wedge a plastic opening pick or tool underneath the plastic backing to start undoing the tabs that connect the backing to the phone.
      • There are 3 tabs on top and bottom and 6 on each side.
      Ask FixBot
    4. ZTE Max XL Display Replacement: step 4, image 1 of 2 ZTE Max XL Display Replacement: step 4, image 2 of 2
      • Remove the two 3.4 mm JIS #00 screws that hold the cable in place—one may be under a lock sticker.
      Ask FixBot
    5. ZTE Max XL Display Replacement: step 5, image 1 of 1
      • Use a nylon spudger to lift the press-fit connector and free the ribbon cable from the main part of the phone.
      Ask FixBot
    6. ZTE Max XL Display Replacement: step 6, image 1 of 1
      • Remove all nineteen 3.4 mm JIS #00 screws from the perimeter of the back.
      Ask FixBot
    7. ZTE Max XL Display Replacement: step 7, image 1 of 1
      • Use an opening tool between the screen and side trim battery cover to remove the screen.
      Ask FixBot
    8. ZTE Max XL Display Replacement: step 8, image 1 of 2 ZTE Max XL Display Replacement: step 8, image 2 of 2
      • Use a nylon spudger to carefully lift the 6 press-fit connections free from the motherboard.
      Ask FixBot
    9. ZTE Max XL Display Replacement: step 9, image 1 of 2 ZTE Max XL Display Replacement: step 9, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Using the iFixit opening tools carefully pry the edge of the battery away from the casing.
      • Do not bend or puncture the battery during this process.
      • If the battery does not lift away freely, use careful amounts of isopropyl alcohol to help soften the adhesive. Gently work a thin opening pick or plastic card along the underside of the battery, pushing the card through the adhesive while lifting the battery free.
      Ask FixBot
    10. ZTE Max XL Display Replacement: step 10, image 1 of 1
      • After taking off the battery and disconnecting all the metal tabs underneath, using the iOPener to break the adhesive between the display and the circuit.
      Ask FixBot
    11. ZTE Max XL Display Replacement: step 11, image 1 of 2 ZTE Max XL Display Replacement: step 11, image 2 of 2
      • Use the plastic opening pick in the iFixit kit to wedge between the display and circuit.
      • Be sure not to damage the wire connecting the display to the circuit.
      • Replace the display and resemble the device following the reverse order
      Ask FixBot
4 other people completed this guide.
Author
with
Isaac Ssaku
293 Reputation
1 Guide authored
IUPUI, Team 1-2, Harley Spring 2022 Member of IUPUI, Team 1-2, Harley Spring 2022
IUPUI-HARLEY-S22S1G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 73
All Time: 654
