Introduction
This guide has step-by-step instructions on how to replace your ZTE Max XL charging port, in order to do this you must first remove the phone's battery. To determine if you need to replace your charging port refer to our Troubleshooting Guide.
Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
After you take out the battery, remove the 8 black wires using the spudger. Flip the metal connectors to release the wires.
One of the tabs will remove the back-facing camera.
7 other people completed this guide.
3 Guide Comments
For someone who is looking to make this as simple as possible it is important to note that although it is super important to disconnect the battery first, you do not need to remove the battery ruining the adhesive. All you need to do after unplugging the battery is disconnect the flex cable and the black jumper wire and pull out the board, this is of course after you have the phone fully opened up. I’m not saying they did it wrong because I know they did it right and very thorough, if you are new to this and working on your own phone in a hurry, do what I said. Good luck in your repairs!
