ZTE Maven Motherboard Replacement
    1. ZTE Maven Motherboard Replacement, Back Cover: step 1, image 1 of 2 ZTE Maven Motherboard Replacement, Back Cover: step 1, image 2 of 2
      • Use your fingers to remove the back cover.
      Ask FixBot
    1. ZTE Maven Motherboard Replacement, SIM Card: step 2, image 1 of 2 ZTE Maven Motherboard Replacement, SIM Card: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the SIM card from the right side of the device using a pair of tweezers.
      Ask FixBot
    1. ZTE Maven Motherboard Replacement, Midframe: step 3, image 1 of 1
      • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
      Ask FixBot
    2. ZTE Maven Motherboard Replacement: step 4, image 1 of 3 ZTE Maven Motherboard Replacement: step 4, image 2 of 3 ZTE Maven Motherboard Replacement: step 4, image 3 of 3
      • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
      Ask FixBot
    1. ZTE Maven Motherboard Replacement, Front Camera: step 5, image 1 of 3 ZTE Maven Motherboard Replacement, Front Camera: step 5, image 2 of 3 ZTE Maven Motherboard Replacement, Front Camera: step 5, image 3 of 3
      Buy
      • Use a pair of tweezers to carefully detach the ribbon cable connecting the camera to the motherboard.
      • Using the tweezers or your fingers, firmly pull up to remove the camera from the phone.
      Ask FixBot
    1. ZTE Maven Motherboard Replacement, Motherboard: step 6, image 1 of 3 ZTE Maven Motherboard Replacement, Motherboard: step 6, image 2 of 3 ZTE Maven Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Detach the clips and cables and carefully and pull the glue pieces off the sides.
      • Remove the motherboard with your fingers.
      Ask FixBot
1 Guide Comment
Is it possible to remove the wifi chip or component. From ZTE Z812 cell. And still be able to use it for talk and text. And if possible where is it located. And how, or where can I have it done, I'm in Houston, Texas. I know it's over kill but that's my question /comment. Thanks for your time.
Damon - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 35
All Time: 847
