Up to 20% off select tools
ZTE Maven Midframe Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
63
All Time:
732
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your ZTE Maven smartphone (released in 2015) has a damaged or cracked midframe that’s affecting the device’s structural integrity, this guide will walk you through how to replace it and extend the phone’s usability.
The midframe serves as a central support for internal components and helps maintain the shape and durability of the phone. A compromised midframe can lead to poor fitment of parts, screen lifting, or long-term wear on internal hardware.
Before starting this repair, inspect the phone for signs of warping, cracks, or loose components that may indicate the midframe needs replacing. If the device still functions properly otherwise, replacing just the midframe can be a cost-effective and sustainable alternative to upgrading.
Before you begin this repair, power off your phone and make sure it is disconnected from the charger.
    1. ZTE Maven Midframe Replacement, Back Cover: step 1, image 1 of 2 ZTE Maven Midframe Replacement, Back Cover: step 1, image 2 of 2
      • Use your fingers to remove the back cover.
      Ask FixBot
    1. ZTE Maven Midframe Replacement, SIM Card: step 2, image 1 of 2 ZTE Maven Midframe Replacement, SIM Card: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the SIM card from the right side of the device using a pair of tweezers.
      Ask FixBot
    1. ZTE Maven Midframe Replacement, Midframe: step 3, image 1 of 1
      • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
      Ask FixBot
    2. ZTE Maven Midframe Replacement: step 4, image 1 of 3 ZTE Maven Midframe Replacement: step 4, image 2 of 3 ZTE Maven Midframe Replacement: step 4, image 3 of 3
      • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Kristen Gismondi
110,399 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 63
All Time: 732
