ZTE Maven Earpiece Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
63
All Time:
612
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your ZTE Maven isn’t producing clear audio—distorted, intermittent, or no sound—through the earpiece, the earpiece may need to be replaced. Follow this guide to replace the earpiece.
The earpiece is a small audio device used to emit noise through the receiver. A faulty earpiece will transmit distorted audio to no audio through the receiver.
Before using the guide, be sure to check the receiver for any debris that may be interfering with the sound quality. The small clump of dust can be removed using a small dust blower. Also be sure to check the volume on the device settings to confirm that the problem is the faulty earpiece.
Be aware of steps 3 and 6 since they require you to work with small, delicate parts of the device, such as the 2mm screws and the ribbon cables. Be sure to turn off the phone and disconnect from any external power sources before removing or replacing any parts of the phone.
Tools
    1. ZTE Maven Earpiece Replacement, Back Cover: step 1, image 1 of 2 ZTE Maven Earpiece Replacement, Back Cover: step 1, image 2 of 2
      • Use your fingers to remove the back cover.
      Ask FixBot
    1. ZTE Maven Earpiece Replacement, SIM Card: step 2, image 1 of 2 ZTE Maven Earpiece Replacement, SIM Card: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the SIM card from the right side of the device using a pair of tweezers.
      Ask FixBot
    1. ZTE Maven Earpiece Replacement, Midframe: step 3, image 1 of 1
      • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
      Ask FixBot
    2. ZTE Maven Earpiece Replacement: step 4, image 1 of 3 ZTE Maven Earpiece Replacement: step 4, image 2 of 3 ZTE Maven Earpiece Replacement: step 4, image 3 of 3
      • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
      Ask FixBot
    1. ZTE Maven Earpiece Replacement, Front Camera: step 5, image 1 of 3 ZTE Maven Earpiece Replacement, Front Camera: step 5, image 2 of 3 ZTE Maven Earpiece Replacement, Front Camera: step 5, image 3 of 3
      Buy
      • Use a pair of tweezers to carefully detach the ribbon cable connecting the camera to the motherboard.
      • Using the tweezers or your fingers, firmly pull up to remove the camera from the phone.
      Ask FixBot
    1. ZTE Maven Earpiece Replacement, Motherboard: step 6, image 1 of 3 ZTE Maven Earpiece Replacement, Motherboard: step 6, image 2 of 3 ZTE Maven Earpiece Replacement, Motherboard: step 6, image 3 of 3
      • Detach the clips and cables and carefully and pull the glue pieces off the sides.
      • Remove the motherboard with your fingers.
      Ask FixBot
    1. ZTE Maven Earpiece Replacement, Earpiece: step 7, image 1 of 2 ZTE Maven Earpiece Replacement, Earpiece: step 7, image 2 of 2
      Buy
      • Disconnect the earpiece from the screen with tweezers or a spudger.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 63
All Time: 612
