ZTE Maven Battery Replacement
      • Remove the back cover.
      Ask FixBot
    1. ZTE Maven Battery Replacement: step 2, image 1 of 2 ZTE Maven Battery Replacement: step 2, image 2 of 2
      • If inserted, remove the SIM card and SD card.
      Ask FixBot
      • Remove midframe screws.
      Ask FixBot
      • Carefully pry between the screen and midframe to release the clips holding it on.
      Ask FixBot
      • Remove the midframe.
      Ask FixBot
    2. Ask FixBot
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Carefully, with a pry pick, pry under the battery to cut the adhesive underneath it.
      • If you are having trouble, apply a heated iOpener onto the battery for another minute, then try again.
      • You can also apply a few drops of high concentration isopropyl alcohol to the edges of the battery to help soften the adhesive.
      Ask FixBot
      • Remove the battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      Ask FixBot
Gigabit87898
16,242 Reputation
3 Guides authored
Master Techs Member of Master Techs
Community
335 Members
8,260 Guides authored
8 Guide Comments
@gigabit87898 you should consider adding images for each step of any guide. A good guide points out where screws are located, what size they are and if they are all the same etc. It is not enough to write "Remove midframe screws". Remember, guides are written for anybody and keep in mind that people wanting to use your guide to fix their device, may not have your knowledge.
oldturkey03 - Reply Share
yeah i dont think im going to use a “heat gun” on my battery
Vinny Games - Reply Share
As long as you do it correctly, it will be fine.
Gigabit87898 - Reply Share
I have a heat gun, but I think I’ll try a hair dryer first. In the comments under disassembly video at youtube one commenter said the adhesive is just double stick tape. Here’s the video: https://www.youtube.com/watch?v=LY5ltw1X...
Clint Murray - Reply Share
Why heat the battery?? I need to change the screen in my moms maven and I'm kinda scared tbh. Lol the protective cover freaks me out!! Help me plzzzz?!?
CaRrIe 4TwIn E - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 37
All Time: 4,613
