Up to 20% off select tools
ZTE Maven 3 Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
66
All Time:
552
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
The screen replacement on a phone becomes essential when the display suffers damage from drops, cracks, or malfunctions such as unresponsive touch or dead pixels. A damaged screen not only affects the visual experience but also impedes usability and may lead to further issues if left unaddressed.
Swapping the screen restores the phone's functionality, ensuring a clear display, responsive touch, and preserving the overall user experience.
    1. ZTE Maven 3 Screen Replacement, Back Cover: step 1, image 1 of 3 ZTE Maven 3 Screen Replacement, Back Cover: step 1, image 2 of 3 ZTE Maven 3 Screen Replacement, Back Cover: step 1, image 3 of 3
      • Locate the small indent on the back right bottom corner of the phone.
      • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
      • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
      Ask FixBot
    1. ZTE Maven 3 Screen Replacement, Battery: step 2, image 1 of 3 ZTE Maven 3 Screen Replacement, Battery: step 2, image 2 of 3 ZTE Maven 3 Screen Replacement, Battery: step 2, image 3 of 3
      • Locate the battery in the middle of the back of the phone.
      • Push in and up on the battery to remove it from its slot.
      • Put the battery aside.
      Ask FixBot
    1. ZTE Maven 3 Screen Replacement, Midframe: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
      Ask FixBot
    2. ZTE Maven 3 Screen Replacement: step 4, image 1 of 1
      • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
      Ask FixBot
    3. ZTE Maven 3 Screen Replacement: step 5, image 1 of 2 ZTE Maven 3 Screen Replacement: step 5, image 2 of 2
      • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
      • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
      • The detached piece is the midframe, and you can place it aside when detached.
      Ask FixBot
    1. ZTE Maven 3 Screen Replacement, Motherboard: step 6, image 1 of 1
      • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
      Ask FixBot
    2. ZTE Maven 3 Screen Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Please locate the black wire that’s attached to gold plates on the left side of the device.
      • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
      Ask FixBot
    3. ZTE Maven 3 Screen Replacement: step 8, image 1 of 2 ZTE Maven 3 Screen Replacement: step 8, image 2 of 2
      • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
      • 2 adhesive ribbon cables (green circles).
      • One ribbon cable that slides out (orange circles).
      • Three ribbon cables that pop in and out (yellow circles).
      Ask FixBot
    4. ZTE Maven 3 Screen Replacement: step 9, image 1 of 3 ZTE Maven 3 Screen Replacement: step 9, image 2 of 3 ZTE Maven 3 Screen Replacement: step 9, image 3 of 3
      • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
      Ask FixBot
    5. ZTE Maven 3 Screen Replacement: step 10, image 1 of 2 ZTE Maven 3 Screen Replacement: step 10, image 2 of 2
      • Grab the opening pick and work it into the edges of the motherboard.
      • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
      • Remove the motherboard and put it aside.
      Ask FixBot
    1. ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: step 11, image 1 of 2 ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: step 11, image 2 of 2
      • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
      Ask FixBot
    1. ZTE Maven 3 Screen Replacement, Screen: step 12, image 1 of 1
      • What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
      Ask FixBot
Author
with
Emma Thiboutot
705 Reputation
8 Guides authored
UMass Dartmouth, Team 3-1, Konn Fall 2023 Member of UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 66
All Time: 552
