ZTE Maven 3 Front Camera Replacement
    1. ZTE Maven 3 Front Camera Replacement, Back Cover: step 1, image 1 of 3 ZTE Maven 3 Front Camera Replacement, Back Cover: step 1, image 2 of 3 ZTE Maven 3 Front Camera Replacement, Back Cover: step 1, image 3 of 3
      • Locate the small indent on the back right bottom corner of the phone.
      • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
      • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
      Ask FixBot
    1. ZTE Maven 3 Front Camera Replacement, Battery: step 2, image 1 of 3 ZTE Maven 3 Front Camera Replacement, Battery: step 2, image 2 of 3 ZTE Maven 3 Front Camera Replacement, Battery: step 2, image 3 of 3
      • Locate the battery in the middle of the back of the phone.
      • Push in and up on the battery to remove it from its slot.
      • Put the battery aside.
      Ask FixBot
    1. ZTE Maven 3 Front Camera Replacement, Midframe: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
      Ask FixBot
    2. ZTE Maven 3 Front Camera Replacement: step 4, image 1 of 1
      • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
      Ask FixBot
    3. ZTE Maven 3 Front Camera Replacement: step 5, image 1 of 2 ZTE Maven 3 Front Camera Replacement: step 5, image 2 of 2
      • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
      • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
      • The detached piece is the midframe, and you can place it aside when detached.
      Ask FixBot
    1. ZTE Maven 3 Front Camera Replacement, Front Camera: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Detach the ribbon cable connecting the camera in the top middle left of the phone.
      • Use blunt tweezers to pull the camera off and put it aside.
      Ask FixBot
Emma Thiboutot
705 Reputation
8 Guides authored
UMass Dartmouth, Team 3-1, Konn Fall 2023 Member of UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 54
All Time: 269
