ZTE Maven 2 Daughterboard Replacement
    1. ZTE Maven 2 Daughterboard Replacement, Back Cover: step 1, image 1 of 3 ZTE Maven 2 Daughterboard Replacement, Back Cover: step 1, image 2 of 3 ZTE Maven 2 Daughterboard Replacement, Back Cover: step 1, image 3 of 3
      • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
      • Work your way around the phone with an opening pick to loosen the rest of the back cover.
      • Remove the cover.
      Ask FixBot
    1. ZTE Maven 2 Daughterboard Replacement, Battery: step 2, image 1 of 1
      • Push in and then up on the bottom of the battery to free it from its compartment.
      • Pull the battery out.
      Ask FixBot
    1. ZTE Maven 2 Daughterboard Replacement, MicroSD Card: step 3, image 1 of 2 ZTE Maven 2 Daughterboard Replacement, MicroSD Card: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
      • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
      Ask FixBot
    1. ZTE Maven 2 Daughterboard Replacement, Midframe: step 4, image 1 of 1
      • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    2. ZTE Maven 2 Daughterboard Replacement: step 5, image 1 of 3 ZTE Maven 2 Daughterboard Replacement: step 5, image 2 of 3 ZTE Maven 2 Daughterboard Replacement: step 5, image 3 of 3
      • Wedge the opening tool between the front and side panel to create a gap.
      • Slide the opening pick around the device to detach the midframe.
      Ask FixBot
    1. ZTE Maven 2 Daughterboard Replacement, Motherboard: step 6, image 1 of 3 ZTE Maven 2 Daughterboard Replacement, Motherboard: step 6, image 2 of 3 ZTE Maven 2 Daughterboard Replacement, Motherboard: step 6, image 3 of 3
      Buy
      • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
      • Remove the six 3 mm screws with a Phillips #00 screwdriver.
      • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
      Ask FixBot
    2. ZTE Maven 2 Daughterboard Replacement: step 7, image 1 of 2 ZTE Maven 2 Daughterboard Replacement: step 7, image 2 of 2
      • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
      Ask FixBot
    3. ZTE Maven 2 Daughterboard Replacement: step 8, image 1 of 2 ZTE Maven 2 Daughterboard Replacement: step 8, image 2 of 2
      • Work the opening pick around the edges of the motherboard to loosen it up.
      • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
      • Pull the motherboard out of the device.
      Ask FixBot
    1. ZTE Maven 2 Daughterboard Replacement, Daughterboard: step 9, image 1 of 1
      • Remove the daughterboard containing the charging port.
      Ask FixBot
Kristen Gismondi
108,586 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,578 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 208
