ZTE Lever Rear Camera Replacement
    1. ZTE Lever Rear Camera Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card and the Sim card from the device.
      • The Sim and SD cards are not shown here as our device did not come with them.
      Ask FixBot
    2. ZTE Lever Rear Camera Replacement: step 2, image 1 of 2 ZTE Lever Rear Camera Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to separate the back from the device.
      Ask FixBot
    3. ZTE Lever Rear Camera Replacement: step 3, image 1 of 2 ZTE Lever Rear Camera Replacement: step 3, image 2 of 2
      • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
      • Remove the cover.
      Ask FixBot
    4. ZTE Lever Rear Camera Replacement: step 4, image 1 of 2 ZTE Lever Rear Camera Replacement: step 4, image 2 of 2
      • Disconnect the battery cable from the motherboard with a plastic opening tool.
      Ask FixBot
    5. ZTE Lever Rear Camera Replacement: step 5, image 1 of 1
      • Use your hands, or a plastic opening tool, to pry the battery from the phone.
      Ask FixBot
    1. ZTE Lever Rear Camera Replacement, Rear Camera: step 6, image 1 of 1
      • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
      Ask FixBot
    2. ZTE Lever Rear Camera Replacement: step 7, image 1 of 3 ZTE Lever Rear Camera Replacement: step 7, image 2 of 3 ZTE Lever Rear Camera Replacement: step 7, image 3 of 3
      • Remove the top plastic motherboard cover using a plastic opening tool.
      Ask FixBot
    3. ZTE Lever Rear Camera Replacement: step 8, image 1 of 2 ZTE Lever Rear Camera Replacement: step 8, image 2 of 2
      • Using a plastic opening tool, disconnect the camera from the motherboard.
      Ask FixBot
    4. ZTE Lever Rear Camera Replacement: step 9, image 1 of 1
      • Remove the camera from the phone.
      Ask FixBot
Michael Gonzalez
501 Reputation
4 Guides authored
USF Tampa, Team S5-G2, Passmore Spring 2018 Member of USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 53
All Time: 453
