Up to 20% off select tools
ZTE Lever Power Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
74
All Time:
754
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Follow this replacement guide to replace the power button on a ZTE Lever smartphone.
    1. ZTE Lever Power Button Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card and the Sim card from the device.
      • The Sim and SD cards are not shown here as our device did not come with them.
      Ask FixBot
    2. ZTE Lever Power Button Replacement: step 2, image 1 of 2 ZTE Lever Power Button Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to separate the back from the device.
      Ask FixBot
    3. ZTE Lever Power Button Replacement: step 3, image 1 of 2 ZTE Lever Power Button Replacement: step 3, image 2 of 2
      • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
      • Remove the cover.
      Ask FixBot
    4. ZTE Lever Power Button Replacement: step 4, image 1 of 2 ZTE Lever Power Button Replacement: step 4, image 2 of 2
      • Disconnect the battery cable from the motherboard with a plastic opening tool.
      Ask FixBot
    5. ZTE Lever Power Button Replacement: step 5, image 1 of 1
      • Use your hands, or a plastic opening tool, to pry the battery from the phone.
      Ask FixBot
    1. ZTE Lever Power Button Replacement, Volume Buttons: step 6, image 1 of 1
      • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
      Ask FixBot
    2. ZTE Lever Power Button Replacement: step 7, image 1 of 3 ZTE Lever Power Button Replacement: step 7, image 2 of 3 ZTE Lever Power Button Replacement: step 7, image 3 of 3
      • Remove the top plastic motherboard cover using a plastic opening tool.
      Ask FixBot
    3. ZTE Lever Power Button Replacement: step 8, image 1 of 2 ZTE Lever Power Button Replacement: step 8, image 2 of 2
      • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
      Ask FixBot
    4. ZTE Lever Power Button Replacement: step 9, image 1 of 2 ZTE Lever Power Button Replacement: step 9, image 2 of 2
      • Peel up the volume button cable from the phone with hands, or plastic opening tool.
      Ask FixBot
    1. ZTE Lever Power Button Replacement, Power Button: step 10, image 1 of 1
      • Disconnect the power button from the motherboard with a plastic opening tool.
      Ask FixBot
    2. ZTE Lever Power Button Replacement: step 11, image 1 of 2 ZTE Lever Power Button Replacement: step 11, image 2 of 2
      • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
      Ask FixBot
Author
with
Michael Gonzalez
501 Reputation
4 Guides authored
USF Tampa, Team S5-G2, Passmore Spring 2018 Member of USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 74
All Time: 754
