ZTE Lever Loud Speaker Replacement
    1. ZTE Lever Loud Speaker Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card and the Sim card from the device.
      • The Sim and SD cards are not shown here as our device did not come with them.
      Ask FixBot
    2. ZTE Lever Loud Speaker Replacement: step 2, image 1 of 2 ZTE Lever Loud Speaker Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to separate the back from the device.
      Ask FixBot
    3. ZTE Lever Loud Speaker Replacement: step 3, image 1 of 2 ZTE Lever Loud Speaker Replacement: step 3, image 2 of 2
      • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
      • Remove the cover.
      Ask FixBot
    4. ZTE Lever Loud Speaker Replacement: step 4, image 1 of 2 ZTE Lever Loud Speaker Replacement: step 4, image 2 of 2
      • Disconnect the battery cable from the motherboard with a plastic opening tool.
      Ask FixBot
    5. ZTE Lever Loud Speaker Replacement: step 5, image 1 of 1
      • Use your hands, or a plastic opening tool, to pry the battery from the phone.
      Ask FixBot
    1. ZTE Lever Loud Speaker Replacement, Volume Buttons: step 6, image 1 of 1
      • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
      Ask FixBot
    2. ZTE Lever Loud Speaker Replacement: step 7, image 1 of 3 ZTE Lever Loud Speaker Replacement: step 7, image 2 of 3 ZTE Lever Loud Speaker Replacement: step 7, image 3 of 3
      • Remove the top plastic motherboard cover using a plastic opening tool.
      Ask FixBot
    3. ZTE Lever Loud Speaker Replacement: step 8, image 1 of 2 ZTE Lever Loud Speaker Replacement: step 8, image 2 of 2
      • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
      Ask FixBot
    4. ZTE Lever Loud Speaker Replacement: step 9, image 1 of 2 ZTE Lever Loud Speaker Replacement: step 9, image 2 of 2
      • Peel up the volume button cable from the phone with hands, or plastic opening tool.
      Ask FixBot
    1. ZTE Lever Loud Speaker Replacement, Power Button: step 10, image 1 of 1
      • Disconnect the power button from the motherboard with a plastic opening tool.
      Ask FixBot
    2. ZTE Lever Loud Speaker Replacement: step 11, image 1 of 2 ZTE Lever Loud Speaker Replacement: step 11, image 2 of 2
      • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
      Ask FixBot
    1. ZTE Lever Loud Speaker Replacement, Motherboard: step 12, image 1 of 2 ZTE Lever Loud Speaker Replacement, Motherboard: step 12, image 2 of 2
      • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
      Ask FixBot
    2. ZTE Lever Loud Speaker Replacement: step 13, image 1 of 1
      • Remove the bottom plastic motherboard cover with your fingers
      Ask FixBot
    3. ZTE Lever Loud Speaker Replacement: step 14, image 1 of 2 ZTE Lever Loud Speaker Replacement: step 14, image 2 of 2
      • Disconnect the camera from the motherboard with a plastic opening tool.
      Ask FixBot
    4. ZTE Lever Loud Speaker Replacement: step 15, image 1 of 1
      • Disconnect the display cable from the motherboard with a plastic opening tool.
      Ask FixBot
    5. ZTE Lever Loud Speaker Replacement: step 16, image 1 of 3 ZTE Lever Loud Speaker Replacement: step 16, image 2 of 3 ZTE Lever Loud Speaker Replacement: step 16, image 3 of 3
      Ask FixBot
    6. ZTE Lever Loud Speaker Replacement: step 17, image 1 of 1
      • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
      Ask FixBot
    7. ZTE Lever Loud Speaker Replacement: step 18, image 1 of 1
      • Pry the motherboard cell battery from its position on the case of the phone
      Ask FixBot
    8. ZTE Lever Loud Speaker Replacement: step 19, image 1 of 3 ZTE Lever Loud Speaker Replacement: step 19, image 2 of 3 ZTE Lever Loud Speaker Replacement: step 19, image 3 of 3
      • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
      Ask FixBot
    9. ZTE Lever Loud Speaker Replacement: step 20, image 1 of 1
      • Remove the motherboard with your fingers.
      Ask FixBot
    1. ZTE Lever Loud Speaker Replacement, Loud Speaker: step 21, image 1 of 2 ZTE Lever Loud Speaker Replacement, Loud Speaker: step 21, image 2 of 2
      • Using the plastic opening tool, remove the speaker.
      Ask FixBot
Luke Kilbourne
294 Reputation
2 Guides authored
USF Tampa, Team S5-G2, Passmore Spring 2018 Member of USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 423
