Up to 20% off select tools
ZTE Lever Front Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
68
All Time:
610
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the front camera from the mother board of the ZTE Lever phone.
    1. ZTE Lever Front Camera Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card and the Sim card from the device.
      • The Sim and SD cards are not shown here as our device did not come with them.
      Ask FixBot
    2. ZTE Lever Front Camera Replacement: step 2, image 1 of 2 ZTE Lever Front Camera Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to separate the back from the device.
      Ask FixBot
    3. ZTE Lever Front Camera Replacement: step 3, image 1 of 2 ZTE Lever Front Camera Replacement: step 3, image 2 of 2
      • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
      • Remove the cover.
      Ask FixBot
    4. ZTE Lever Front Camera Replacement: step 4, image 1 of 2 ZTE Lever Front Camera Replacement: step 4, image 2 of 2
      • Disconnect the battery cable from the motherboard with a plastic opening tool.
      Ask FixBot
    5. ZTE Lever Front Camera Replacement: step 5, image 1 of 1
      • Use your hands, or a plastic opening tool, to pry the battery from the phone.
      Ask FixBot
    1. ZTE Lever Front Camera Replacement, Front Camera: step 6, image 1 of 2 ZTE Lever Front Camera Replacement, Front Camera: step 6, image 2 of 2
      • Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
      • Pry off the plastic cover using the iFixit opening tool.
      Ask FixBot
    2. ZTE Lever Front Camera Replacement: step 7, image 1 of 2 ZTE Lever Front Camera Replacement: step 7, image 2 of 2
      • Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
      • Remove the camera from the motherboard.
      Ask FixBot
Author
with
Eric Lilling
169 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 68
All Time: 610
