Up to 20% off select tools
ZTE Lever Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
68
All Time:
1,554
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will describe and show how to replace ZTE Lever lithium ion battery.
    1. ZTE Lever Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card and the Sim card from the device.
      • The Sim and SD cards are not shown here as our device did not come with them.
      Ask FixBot
    2. ZTE Lever Battery Replacement: step 2, image 1 of 2 ZTE Lever Battery Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to separate the back from the device.
      Ask FixBot
    3. ZTE Lever Battery Replacement: step 3, image 1 of 2 ZTE Lever Battery Replacement: step 3, image 2 of 2
      • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
      • Remove the cover.
      Ask FixBot
    4. ZTE Lever Battery Replacement: step 4, image 1 of 2 ZTE Lever Battery Replacement: step 4, image 2 of 2
      • Disconnect the battery cable from the motherboard with a plastic opening tool.
      Ask FixBot
    5. ZTE Lever Battery Replacement: step 5, image 1 of 1
      • Use your hands, or a plastic opening tool, to pry the battery from the phone.
      Ask FixBot
Author
with
Michael Gonzalez
501 Reputation
4 Guides authored
USF Tampa, Team S5-G2, Passmore Spring 2018 Member of USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 68
All Time: 1,554
