ZTE Compel Speaker Replacement
    1. ZTE Compel Speaker Replacement, Battery: step 1, image 1 of 1
      • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
      Ask FixBot
    2. ZTE Compel Speaker Replacement: step 2, image 1 of 1
      • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
      Ask FixBot
    3. ZTE Compel Speaker Replacement: step 3, image 1 of 1
      • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
      • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
      Ask FixBot
    1. ZTE Compel Speaker Replacement, Speaker: step 4, image 1 of 2 ZTE Compel Speaker Replacement, Speaker: step 4, image 2 of 2
      • Remove the 9 screws that measure 4 mm Phillips. Use your PH000 screwdriver attachment.
      • Use your iFixit Magnetic Project Mat to hold your removed screws while working on your ZTE Compel
      Ask FixBot
    2. ZTE Compel Speaker Replacement: step 5, image 1 of 3 ZTE Compel Speaker Replacement: step 5, image 2 of 3 ZTE Compel Speaker Replacement: step 5, image 3 of 3
      • Insert the flat end of your black plastic spudger into the crease and work it around the entire circumference of the phone until the front and back are separated.
      Ask FixBot
    3. ZTE Compel Speaker Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • The speaker is located in the top-left corner of the back plate. Using your tweezers, grip the sides of the speaker and pull it out.
      • Be cautious pulling the speaker out as it might move while pulling it due to adhesive wearing away.
      Ask FixBot
Tayler McCleese
246 Reputation
2 Guides authored
Ohio State, Team S1-G4, Whitney Fall 2018 Member of Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 66
All Time: 583
