ZTE Blade Z Max Fingerprint Sensor Replacement
    1. ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: step 1, image 1 of 3 ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: step 1, image 2 of 3 ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: step 1, image 3 of 3
      • Turn the device on it side with the buttons away from you.
      • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
      • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
      Ask FixBot
    2. ZTE Blade Z Max Fingerprint Sensor Replacement: step 2, image 1 of 3 ZTE Blade Z Max Fingerprint Sensor Replacement: step 2, image 2 of 3 ZTE Blade Z Max Fingerprint Sensor Replacement: step 2, image 3 of 3
      • Pull the tray out with your fingers .
      • Remove the SIM card.
      Ask FixBot
    1. ZTE Blade Z Max Fingerprint Sensor Replacement, Fingerprint Sensor: step 3, image 1 of 1
      • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
      Ask FixBot
    2. ZTE Blade Z Max Fingerprint Sensor Replacement: step 4, image 1 of 2 ZTE Blade Z Max Fingerprint Sensor Replacement: step 4, image 2 of 2
      • Insert a plastic opening tool into the space where the SIM card tray used to be.
      • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
      Ask FixBot
    3. ZTE Blade Z Max Fingerprint Sensor Replacement: step 5, image 1 of 2 ZTE Blade Z Max Fingerprint Sensor Replacement: step 5, image 2 of 2
      • Insert the plastic opening tool into the space you created between the phone back and frame.
      • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
      Ask FixBot
    4. ZTE Blade Z Max Fingerprint Sensor Replacement: step 6, image 1 of 2 ZTE Blade Z Max Fingerprint Sensor Replacement: step 6, image 2 of 2
      • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
      • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
      • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
      • Set the phone back aside.
      Ask FixBot
    5. ZTE Blade Z Max Fingerprint Sensor Replacement: step 7, image 1 of 1
      • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
      • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
      Ask FixBot
    6. ZTE Blade Z Max Fingerprint Sensor Replacement: step 8, image 1 of 2 ZTE Blade Z Max Fingerprint Sensor Replacement: step 8, image 2 of 2
      • Turn the phone over, with the screen up.
      • Insert the opening tool between the screen and the silver trim that surrounds it.
      • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
      Ask FixBot
    7. ZTE Blade Z Max Fingerprint Sensor Replacement: step 9, image 1 of 2 ZTE Blade Z Max Fingerprint Sensor Replacement: step 9, image 2 of 2
      • Turn the phone back over, with the screen down.
      • Lift the trim piece off of the phone and set aside.
      Ask FixBot
    8. ZTE Blade Z Max Fingerprint Sensor Replacement: step 10, image 1 of 2 ZTE Blade Z Max Fingerprint Sensor Replacement: step 10, image 2 of 2
      • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 66
All Time: 1,391
