ZTE Blade Spark Screen Replacement
    1. ZTE Blade Spark Screen Replacement, Screen: step 1, image 1 of 1
      • Place phone screen side down on a flat surface.
      Ask FixBot
    2. ZTE Blade Spark Screen Replacement: step 2, image 1 of 2 ZTE Blade Spark Screen Replacement: step 2, image 2 of 2
      • Take an opening tool, and insert it between the phone's backplate and chassis.
      • Work the tool all the way around perimeter of the phone until the backplate is free.
      Ask FixBot
    3. ZTE Blade Spark Screen Replacement: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
      Ask FixBot
    4. ZTE Blade Spark Screen Replacement: step 4, image 1 of 1
      • Remove the middle plate that was unscrewed from the previous step.
      • At this stage you should have 3 separate parts as shown.
      • For the next step you will be working on the middle part in this picture.
      Ask FixBot
    5. ZTE Blade Spark Screen Replacement: step 5, image 1 of 1
      • Take black covering off of battery.
      Ask FixBot
    6. ZTE Blade Spark Screen Replacement: step 6, image 1 of 2 ZTE Blade Spark Screen Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Unclip fastener located in the red box. Blunt end tweezers are recommended for this process.
      Ask FixBot
    7. ZTE Blade Spark Screen Replacement: step 7, image 1 of 2 ZTE Blade Spark Screen Replacement: step 7, image 2 of 2
      • Remove battery so you are left with the base of the phone, the battery, and the battery cover separated.
      Ask FixBot
    8. ZTE Blade Spark Screen Replacement: step 8, image 1 of 1
      • Remove the 4mm screws in the 2 red circles shown with the Phillips #00 screwdriver.
      Ask FixBot
    9. ZTE Blade Spark Screen Replacement: step 9, image 1 of 1
      • Heat all 4 sides of the piece with the iOpener to loosen adhesive.
      Ask FixBot
    10. ZTE Blade Spark Screen Replacement: step 10, image 1 of 2 ZTE Blade Spark Screen Replacement: step 10, image 2 of 2
      • Now remove the screen from it's base using the opening tool.
      Ask FixBot
Swap your old screen with your new screen. To reassemble your device with a new screen, follow these instructions in reverse order.
Solomon Barket
181 Reputation
1 Guide authored
IUPUI, Team 1-3, Harley Spring 2023 Member of IUPUI, Team 1-3, Harley Spring 2023
IUPUI-HARLEY-S23S1G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 30
All Time: 710
