ZTE Blade Spark Rear-Facing Camera
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
95
All Time:
3,167
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
Follow this guide to disassemble the ZTE Blade Spark device and replace the rear-facing camera.
    1. ZTE Blade Spark Rear-Facing Camera, ZTE Blade Spark Rear-Facing Camera: step 1, image 1 of 1
      • First, apply heat evenly on the back cover using a heat sack to soften the adhesive.
      Ask FixBot
    2. ZTE Blade Spark Rear-Facing Camera: step 2, image 1 of 1
      • Now, carefully remove the back cover.
      Ask FixBot
    3. ZTE Blade Spark Rear-Facing Camera: step 3, image 1 of 1
      • Once opened, Locate and remove all exposed screws using a Phillips-Head screwdriver and set them aside.
      Ask FixBot
    4. ZTE Blade Spark Rear-Facing Camera: step 4, image 1 of 1
      • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
      Ask FixBot
    5. ZTE Blade Spark Rear-Facing Camera: step 5, image 1 of 1
      • After removing the white plastic panel, you should see a black metal battery cover.
      • To remove the metal battery cover, remove the screws from the panel using a Phillips screwdriver if you have not yet done so.
      Ask FixBot
    6. ZTE Blade Spark Rear-Facing Camera: step 6, image 1 of 1
      • Then, simple lift to remove the metal battery cover.
      Ask FixBot
    7. ZTE Blade Spark Rear-Facing Camera: step 7, image 1 of 1
      • You have reached the Fingerprint Scanner, the device Battery, and Front Facing Camera.
      Ask FixBot
    8. ZTE Blade Spark Rear-Facing Camera: step 8, image 1 of 3 ZTE Blade Spark Rear-Facing Camera: step 8, image 2 of 3 ZTE Blade Spark Rear-Facing Camera: step 8, image 3 of 3
      • Proceeding with disassembly, next up is the top chipset which the Rear Facing Camera is attached to.
      • To detach the chipset and reach the Rear Camera, locate and disconnect five power connectors surrounding the top chipset (as shown in images).
      Ask FixBot
    9. ZTE Blade Spark Rear-Facing Camera: step 9, image 1 of 1
      • Once you have the power connectors disconnected from the top chipset, use a Phillips screwdriver to remove the final screw located at the very top of the chipset (as shown in image).
      Ask FixBot
    10. ZTE Blade Spark Rear-Facing Camera: step 10, image 1 of 1
      • Then, simply lift chipset from top and detach from the device frame.
      Ask FixBot
    11. ZTE Blade Spark Rear-Facing Camera: step 11, image 1 of 1
      • You have now reached the final replacement component of the device, the Rear Facing Camera!
      • For step-by-step instructions on replacing any of the device components covered throughout the disassembly process, check out our ZTE Blade Spark Replacement guides.
      Ask FixBot
2 other people completed this guide.
Hung Vu
632 Reputation
1 Guide authored
Gateway, Team S1-G6, Johnson Spring 2018 Member of Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 95
All Time: 3,167
