Up to 20% off select tools
ZTE Awe Screen Replacement
Views: 15K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
102
All Time:
14,962
Comments: 3
3 comments on steps.
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This is a total breakdown of the phone, and requires you to dissemble the parts pictured in order to access the screen.
    1. ZTE Awe Screen Replacement, Detach the mid frame: step 1, image 1 of 1
      • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
      Ask FixBot
    2. ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: step 2, image 1 of 3 ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: step 2, image 2 of 3 ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: step 2, image 3 of 3
      • Wedge the flat end of the spudger between the mid frame and the digitizer.
      Ask FixBot
    3. ZTE Awe Screen Replacement, Expose the motherboard: step 3, image 1 of 2 ZTE Awe Screen Replacement, Expose the motherboard: step 3, image 2 of 2
      • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
      Ask FixBot
    4. ZTE Awe Screen Replacement, Remove the ribbon wires: step 4, image 1 of 3 ZTE Awe Screen Replacement, Remove the ribbon wires: step 4, image 2 of 3 ZTE Awe Screen Replacement, Remove the ribbon wires: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to remove the four ribbon wires on the sides of the device.
      Ask FixBot
    5. ZTE Awe Screen Replacement, Orient the motherboard: step 5, image 1 of 1
      • Orient the motherboard to expose the mid frame.
      Ask FixBot
    6. ZTE Awe Screen Replacement, Remove the connector: step 6, image 1 of 3 ZTE Awe Screen Replacement, Remove the connector: step 6, image 2 of 3 ZTE Awe Screen Replacement, Remove the connector: step 6, image 3 of 3
      • Remove the connector to free the motherboard from the screen.
      Ask FixBot
    1. ZTE Awe Screen Replacement, Remove the cover: step 7, image 1 of 1
      • Remove the back cover from the phone.
      Ask FixBot
    2. ZTE Awe Screen Replacement, Remove battery: step 8, image 1 of 1
      • Pry the battery up and out of the phone.
      Ask FixBot
    3. ZTE Awe Screen Replacement: step 9, image 1 of 3 ZTE Awe Screen Replacement: step 9, image 2 of 3 ZTE Awe Screen Replacement: step 9, image 3 of 3
      • Gently wedge the spudger in between the glass screen and the mid frame.
      Ask FixBot
    4. ZTE Awe Screen Replacement, Separate the motherboard from the screen: step 10, image 1 of 2 ZTE Awe Screen Replacement, Separate the motherboard from the screen: step 10, image 2 of 2
      • Carefully pry the screen away from the motherboard.
      Ask FixBot
    5. ZTE Awe Screen Replacement, Remove the ribbons: step 11, image 1 of 3 ZTE Awe Screen Replacement, Remove the ribbons: step 11, image 2 of 3 ZTE Awe Screen Replacement, Remove the ribbons: step 11, image 3 of 3
      • Be careful when removing the ribbon wires. They are delicate.
      Ask FixBot
    6. ZTE Awe Screen Replacement, Remove the remaining ribbons: step 12, image 1 of 3 ZTE Awe Screen Replacement, Remove the remaining ribbons: step 12, image 2 of 3 ZTE Awe Screen Replacement, Remove the remaining ribbons: step 12, image 3 of 3
      • Remove the remaining two ribbon wires from their connectors.
      Ask FixBot
    7. ZTE Awe Screen Replacement, Expose the digitizer: step 13, image 1 of 3 ZTE Awe Screen Replacement, Expose the digitizer: step 13, image 2 of 3 ZTE Awe Screen Replacement, Expose the digitizer: step 13, image 3 of 3
      • Wedge the plastic spudger between the screen and the digitizer.
      • Gently pry apart the screen from the digitizer.
      Ask FixBot
12 other people completed this guide.
Author
with
Jennifer DeMeo
1,035 Reputation
5 Guides authored
USF Tampa, Team 1-2, Leahy Fall 2014 Member of USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 102
All Time: 14,962
