ZTE Awe Motherboard Replacement
    1. ZTE Awe Motherboard Replacement, Remove the back cover: step 1, image 1 of 1
      • Remove the back cover of the phone to expose the phone's mid-frame.
      Ask FixBot
    2. ZTE Awe Motherboard Replacement, Remove battery: step 2, image 1 of 1
      • Pry the battery up and out of the phone.
      Ask FixBot
    1. ZTE Awe Motherboard Replacement, Detach the mid frame: step 3, image 1 of 1
      • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
      Ask FixBot
    2. ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: step 4, image 1 of 3 ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: step 4, image 2 of 3 ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: step 4, image 3 of 3
      • Wedge the flat end of the spudger between the mid frame and the digitizer.
      Ask FixBot
    3. ZTE Awe Motherboard Replacement, Expose the motherboard: step 5, image 1 of 2 ZTE Awe Motherboard Replacement, Expose the motherboard: step 5, image 2 of 2
      • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
      Ask FixBot
    4. ZTE Awe Motherboard Replacement, Remove the ribbon wires: step 6, image 1 of 3 ZTE Awe Motherboard Replacement, Remove the ribbon wires: step 6, image 2 of 3 ZTE Awe Motherboard Replacement, Remove the ribbon wires: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to remove the four ribbon wires on the sides of the device.
      Ask FixBot
    5. ZTE Awe Motherboard Replacement, Orient the motherboard: step 7, image 1 of 1
      • Orient the motherboard to expose the mid frame.
      Ask FixBot
    6. ZTE Awe Motherboard Replacement, Remove the connector: step 8, image 1 of 3 ZTE Awe Motherboard Replacement, Remove the connector: step 8, image 2 of 3 ZTE Awe Motherboard Replacement, Remove the connector: step 8, image 3 of 3
      • Remove the connector to free the motherboard from the screen.
      Ask FixBot
5 other people completed this guide.
Jennifer DeMeo
1,035 Reputation
5 Guides authored
USF Tampa, Team 1-2, Leahy Fall 2014 Member of USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 101
All Time: 2,378
