ZTE Avail 2 Battery Replacement
    1. ZTE Avail 2 Battery Replacement, Battery: step 1, image 1 of 3 ZTE Avail 2 Battery Replacement, Battery: step 1, image 2 of 3 ZTE Avail 2 Battery Replacement, Battery: step 1, image 3 of 3
      • Before disassembling your ZTE Avail 2, be sure it is powered off.
      • Remove the back cover using the notch at the bottom of the device.
      • Pull the back cover from the front panel gently to remove it.
      Ask FixBot
    2. ZTE Avail 2 Battery Replacement: step 2, image 1 of 2 ZTE Avail 2 Battery Replacement: step 2, image 2 of 2
      • Remove the battery by the notch in the back plate.
      • Once you have removed the battery replace it with the new one.
      • Carefully insert the new battery with the connectors aligned correctly.
      • Gently push down on the battery until it clicks into place.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 110
All Time: 1,036
